Why does my bone-stock '02 automatic Z28 dyno only 280.9 rwhp @ 295.7 ft-lb.?!
Old Nov 28, 2004 | 07:37 AM
  #16
damon_Z's Avatar
Re: Why does my bone-stock '02 automatic Z28 dyno only 280.9 rwhp @ 295.7 ft-lb.?!
Originally Posted by mebanditws6
Yes, change your spark plugs and get some NKG's like mine, preferibably the Iridium version instead of the Delcos. Also, get a can of GM Top Engine Cleaner from the dealership and run that through. If you're familiar with Seafoam, this is basically the same except it comes in a spray can. After driving the car warmed up, disconnect both AIR hoses (right by the coil packs) and spray a can of this stuff into the throttle body while the engine is running. Let the car sit for at least 30minutes and start back up. Your car will blow out huge amounts of smoke from burning off the cleaner and carbon. What this does is clean out your combustion chamber and prevents any hot spots that could cause pre-ignition. With this and a plug change, you should dyno in the 290's.
Jason
I think I'll just do what you say, except for getting the Iridium versions. I have a set of TR-55's that a friend got as a birthday gift for me a couple of years ago, so I won't let that go to waste. I know that they're good for only 20,000 miles, but I'm betting that I'll have longtubes installed before then and I'll be able to switch to the Iridiums or to the Bosch Platinums. I'll definitely use that GM Top Engine Cleaner and maybe even get another baseline dyno after the plug change. Doing a plug change and using an engine cleaner aren't mods, right?
Old Nov 28, 2004 | 08:37 AM
  #17
mrr23's Avatar
i have to formulas
the 99 formy went 13.56 @ 103.27
the 00 formy went 13.60 @ 101.66
both 3.23 autos. go figure. just enjoy the car.
Old Nov 28, 2004 | 09:13 AM
  #18
DanBUCF's Avatar
I would change those spark plugs for sure...this is what all 8 of my plugs looked like at 47,000 miles...Factory Delco plugs.
http://www.mustangmods.com/data/5431/dsc01770.jpg
Old Nov 28, 2004 | 08:38 PM
  #19
Capn Pete's Avatar
That actually looks pretty good to me, considering the mileage! They've got that nice "tan" color to them (and there's no carbon build-up or anything).
Old Nov 29, 2004 | 12:06 PM
  #20
mebanditws6's Avatar
no, just good maintenance.
Jason
Old Nov 29, 2004 | 01:21 PM
  #21
Ed Blown Vert's Avatar
That is about right. Mine dynoed 279 when stock.
Old Nov 29, 2004 | 05:39 PM
  #22
damon_Z's Avatar
I just made an appointment with TT Performance for this Saturday to dyno the car with air/fuel ratio, KR, and timing monitoring after they do a plug and wire installation. This will be my third set of baseline dynos, but this one will tell me if there really is something wrong with my car or not. I'm hoping there is something wrong with my car so that I can find out how to fix it and hopefully free up at least 25 rwhp that seems to be missing right now.
Old Nov 29, 2004 | 09:56 PM
  #23
danno02SS's Avatar
Re: Update
Max Power = 285.1
Max Torque = 302.0
Air Fuel Ratio was 11.9.
The car seems to have gained 4 hp and 5 ft-lb. of torque just through mileage alone. Ray, at Performance Specialties, mentioned that the car was running fat and could gain 15 horsepower through dyno-tuning. Could my air fuel ratio be the reason why my car is dynoing lower than other stock f-bodies? Also, regarding my times in my original post, I forgot to mention that 5 of the 6 passes were done when the transmission was engaged in overdrive. Does that make a difference? Thanks in advance for the info.
I don't know if leaning the A/F alone is going to get you 15hp. My guess is more like 3-8hp. I think your car's rich condition is being caused by knock. The PCM richens the fuel mixture and pulls timing when it detects it.
My baseline numbers at 6389mi are in the sig. The car has the optional SLP CME catback which might be worth 5rwhp. I think your car should be right at the 300rwhp/315rwtq mark.
Old Nov 29, 2004 | 10:12 PM
  #24
FLeXNuTZ's Avatar
Originally Posted by Capn Pete
Mine only dyno'd 288 HP / 307 TQ a couple months ago with the setup in my sig. Your #'s may be on the lower side (the MPH reflects the RWHP)
So what do stock LT1s put to the wheels? If 280 rwhp=101 mph in the 1/4 then the LT1 shouldn't be far behind. What, maybe 270-275 rwhp? Just bringing this up because I've personally witnessed a lot of people swear up and down that the LS1 is 50 rwhp stronger than the LT1 mod for mod in any stock or "lightly" modded situation. Not trying to start the BSing but this is what I've been told and have seen over and over again.
Old Nov 29, 2004 | 11:50 PM
  #25
Capn Pete's Avatar
Typically, LS1's run between ~105 - 108 mph (with obvious exceptions, higher and lower). I can't speak for all LT1's, but the ones I've seen have all run between ~96 - 100 mph (I'm talking about stock, or close to stock #'s here as well).
I think that a "rule-of-thumb" is that every MPH is *roughly* ~10 HP, so if an LT1 does ~100 MPH, and an LS1 does ~105 MPH, then that's around ~50 HP difference, right?
.....not saying it's all an exact science, but these are just some commonly agreed upon facts/myths that I've come to know.
Old Nov 30, 2004 | 12:13 AM
  #26
robb4964's Avatar
That looks pretty close to me Pete . Numbers dont lie .
Old Nov 30, 2004 | 03:55 AM
  #27
AL SS590 M6's Avatar
Moderator
It doesn't look so bad to me...you just didn't get a freak of a car I guess. Nothing to worry about. Its still pretty damn fast. Get those 60' times down to soemthing respectable and you'll be gonig low 13's...which is right on par for a completely stock car. Who care's what the dyno says anyhow? How quick the car goes is really what is important, right?
At that DA he should already be very low 13s at 106-107 on the 2.0 60s that he's pulling.
But for every freak there's a counter part.
Back when the LS1 f-bodies first came out there was a group of 6 or 7 of us that all had M6 cars. We'd all go to the track together and everyone would run low to mid 13s at 106-107 except for one TA it would run high 13s at 102-103 and it didn't matter who was driving it either. As we all modded our cars this one stayed slower mod for mod. To this day we have never figured out why.
Old Nov 30, 2004 | 03:59 AM
  #28
Moderator
Re: Update
I've been thinking about getting the plugs changed, but would you still recommend that after you read the following update?
Max Power = 285.1
Max Torque = 302.0
With the car running that rich a lot of power could be gained by a good tune.
D or OD makes no difference in 1/4 mile times.
Old Nov 30, 2004 | 04:02 AM
  #29
Moderator
Originally Posted by mrr23
i have to formulas
Yes but have you ever run in negative DAs down in the swamp?
Old Dec 2, 2004 | 09:34 AM
  #30
Before you go, run a can of GM Top Engine Cleaner through the motor (via throttle body). Since you're running pretty rich, it's likely you're getting too much knock retard which will pull back timing and enrichen the fuel mixture. Carbon buildup will cause "hotspots" in various areas of the combustion chamber and cause more detonation, at which the point the computer will go into KR to help protect the engine from excessive comb. temps.
Jason
