Who has Hooker 1 7/8" Longtubes?
Old Aug 1, 2007 | 01:38 PM
350 HRSS's Avatar
So who in here has the Hooker 1 7/8" long tubes installed on their car?
How was the install? Was it a tight fit? Anyone have pics?
I did a search, but didn't find much info. Is this basically a "race" header?
Thanks!
Old Aug 1, 2007 | 05:13 PM
SSpdDmon's Avatar
If you're running stock cubes, that'll be too much primary. You may not acheive full gains.
Old Aug 1, 2007 | 07:02 PM
Kraest's Avatar
Retired
1-7/8" is good for stroker motors.
You'll lose low-end and possibly even peak torque compared to 1-3/4" with them on your stock-displacement motor.
Best-case scenario is someone who makes a 1-3/4"-1-7/8" stepped header like LG Motorsports for the Corvettes with the longest collector that you can find. (32-34" or so)
Mike
Old Aug 2, 2007 | 01:19 AM
Bayer-Z28's Avatar
a Friend around here (alamo nm) has them. I didn't get into much as far as the install, but the ground clearance is AMAZING!!!
I really had to get down on my knees and look for them! But as far as the primaries, 1 3/4" primaries is sufficient for a stock cubed LS1.
Old Aug 2, 2007 | 07:31 AM
350 HRSS's Avatar
Thanks for the replies Just wanted to get some ideas on what to look for!! Great info on the ground clearance, was wondering about that!
Old Aug 3, 2007 | 12:49 PM
WS6NIGHTMARE's Avatar
I have the 1 3/4 SC's. Great header, no clearance issues at all.
Old Aug 3, 2007 | 12:56 PM
350 HRSS's Avatar
Does the driver's side have a slip joint? My LT1 HSC had a slip joint that was a real pain. And I switched over to PaceSetters, but had fitment issues. Driver's side floor pan had to be banged in, and then we had to cut and reweld the pass. side motor mount so the pass. side would fit.
Really crazy stuff, I don't want to go through again.
Old Aug 3, 2007 | 01:06 PM
My y-pipe is welded up. If they would have needed all that work, I would have scrapped them. No banging or anything on mine. I have a rattle in the back of the car, but thats going to be something with the Borla.
Old Aug 3, 2007 | 01:08 PM
350 HRSS's Avatar
I didn't mention anything to do w/ the ypipe. No problems w/ that. And there was no way I was scrapping them, b/c they were basically free
I just know I won't go the PaceSetter route any more.
Thanks.
Old Aug 3, 2007 | 01:10 PM
Were you meaning where the y-pipe goes up to the collector?
Old Aug 3, 2007 | 01:24 PM
350 HRSS's Avatar
No, the ypipe was not the issue.....one of the primaries on the pass. side was hitting the motor mount. The pass. side floor banging wasn't a hard issue to fix. But the motor mount was a b*tch. We had to REMOVE it, cut out a chunk of it, and reweld the chunk back in.
A thread w/ PICS can be found in the LT1 tech section.
Old Aug 4, 2007 | 11:15 AM
Then as dumb as I feel for saying it, I dont know what you mean by the slip joint...
Old Aug 4, 2007 | 11:42 AM
Sparkz28ss's Avatar
Sometimes one of the primary tubes will have a slip joint on it to clear things like the steering shaft.....
ASM mids come to mind...as well as hooker super comps for the third gens..
Old Aug 4, 2007 | 11:45 AM
Oh ok, I was thinking where the collecter meets the y-pipe. Come to think of it I have seen a kit or 2 like that, just never pated any attention to it.
Old Aug 4, 2007 | 08:53 PM
GreenDemon's Avatar
Has anyone tried the Kooks 1&7/8"-2" x 3&1/2" headers yet? I don't suppose they'll make much sense on a bolt-on car, but maybe around 600+ rwhp you might see some gains...
tdigger9899
Sep 7, 2015 10:56 AM
97SSdude
Aug 21, 2015 09:36 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
jbc3
Jul 28, 2015 12:24 PM
