Where to get signal for AF gauges on a 99?
Old Dec 15, 2003 | 08:41 PM
Mike94ZLT1's Avatar
Hey guys, I'm installing AF gauges in my car, and I need to know where I need to get the signal for the sensor. Can I tap directly into the 02 sensor, or do I have to go to the wiring harness of the car? Thanks! -Mike
Old Dec 15, 2003 | 08:54 PM
Aklaim's Avatar
DO NOT TAP THE O2 WIRE!!! You wont get an accurate reading if you do. You need to take it from the computer, im not sure which wire. Ask around; I'm sure somebody has the answer.
Old Dec 15, 2003 | 09:10 PM
Mike94ZLT1's Avatar
Thanks! Now, Which wire?! Should I run the wires through the engine bay to by the PCM? Thanks guys
Old Dec 16, 2003 | 11:15 PM
iateyour5.0's Avatar
Try going here http://autometer.com/hp/ click on insructions then click on AF gauges, but you have to have adobe reader. Hope it helps.
Old Dec 17, 2003 | 02:03 AM
Mike94ZLT1's Avatar
Thanks!
Old Dec 22, 2003 | 05:28 PM
Mike94ZLT1's Avatar
I've looked around on that site, and I can't find the right wire. Any suggestions?
Old Dec 22, 2003 | 05:31 PM
My84Z's Avatar
first off the gauge isn't all that acurate to begin with and secondly the 02 is the same signal as at the pcm. just tap into the purple wire and the purple wire with a stripe on the 02's.
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
Aaront810
Sep 11, 2015 11:24 AM
jackpawt883
Sep 10, 2015 08:53 PM
