Whats the poundage on a stock LS1 fuel injectors
Old Feb 8, 2008 | 12:42 PM
Ironxcross's Avatar
On a 99' Z28, if it makes a difference.
Old Feb 8, 2008 | 01:31 PM
soul strife's Avatar
26 lbs on the 99'
Old Feb 8, 2008 | 04:19 PM
Kraest's Avatar
Retired
97-98 = 28#
99-00 = 26#
01-04 = 28#
Old Feb 8, 2008 | 07:01 PM
Bayer-Z28's Avatar
^ Based on that, they may be maxed at stock? Correct me if I'm wrong, but doesn't the HP output correlate to the injector sizing? 450 FWHP would be 42#ers?
Old Feb 8, 2008 | 11:07 PM
Kraest's Avatar
Retired
Nah. The stock 26-28s are good for a cam-only car... figure around 400+ for the 26s and 420+ for the 28s or upwards of 475-500 crank horsepower.
That's pretty much maxxed. You only need 30# SVOs for a heads/cam car making upwards of 450-470rwhp. That's all I used in mine. I used 42s in my 408ci 530rwhp, but they weren't even close to being maxxed out.
I know that Al is going to disagree with me on this , but when you use tuning programs like LS1 Edit or EFI Live, you actually set the SVO 30# to 36# on the program because they are rated at 30# using Ford's fuel pressure, not the LS1 fuel pressure.
Mike
Old Feb 8, 2008 | 11:11 PM
mdacton's Avatar
Mike
what is the stock pressure?
When I tuned my car I set them to 30's and run 55psi..... But I had to try it to make it work and it did
Old Feb 9, 2008 | 12:18 AM
Kraest's Avatar
Retired
Stock pressure on the LT1 is around 43psi.
Stock pressure on the LS1 is 58psi.
Old Feb 9, 2008 | 09:09 AM
EvilBird's Avatar
Hey i got to get injectors, 2000 T/A , Cartek stage 2 heads/2x cam/headers...... Cartek told me 36's what brand should i get?
Old Feb 9, 2008 | 10:16 AM
Zitty'sZ's Avatar
Ford SVO 30 pounders seem to be the most popular. They actually flow around 36 lbs with GM's higher fuel pressure and you can usually find used sets for $200 or less .
Old Feb 9, 2008 | 10:40 AM
EvilBird's Avatar
Sweet thanks bro
AdsoYo
May 2, 2018 03:21 AM
Catmaigne
Dec 25, 2014 12:16 PM
Jul 4, 2005 05:00 PM
