what would it take to produce big numbers?
Old Feb 23, 2006 | 12:29 AM
LarrieuY2KSS's Avatar
Exclamation what would it take to produce big numbers?
what would it take to build an all motor (NA) to put out around 550-600 rear wheel on an M6 car, 402, 408? I know a 12 bolt would handle it all, just curious of what it would take to put that out.
Old Feb 23, 2006 | 06:06 AM
teke184's Avatar
Re: what would it take to produce big numbers?
Victory Lane 427ci Longblock
Description:
All of our VRE 427ci engines utilize a Compstar M.I.D. Wet-Sleeve block, forged internals, and coated pistons. As part of our Victory Lane series this engine features coated bearings through-out the entire short block. Whether your building a retro street machine or a modern day track warrior the Victory Lane 427 is the ultimate choice for power.
Specs:
Compstar M.I.D. Block
Compstar 6.125" LS1 Rods
Eagle 4.000" Crankshaft
Diamond Custom Pistons
Diamond Pro Select Rings
ET Perforamnce CNC Cylinder Heads
Comp Cams Hydraulic Lifters
GM Production Rocker Arms
Cometic MLS Head Gaskets
VRE Custom Spec Camshaft
VRE Ported LS6 Oil Pump
Adjustable Timing Set
Chromemoly Pushrods
Clevite Rod Bearings
Clevite Main Bearings
Clevite Camshaft Bearings
ARP Main Studs
ARP Head Studs
All Bearings Coated
Fully Machined Block w/Deck Plates
Balance Rotating Assembly
Blueprint and Assemble
and the biggest custom cam you can find. should get you in the ball park of what you're looking for.
Old Feb 23, 2006 | 11:52 AM
camarookid's Avatar
what he said......... maybe some headers too haha
Old Feb 23, 2006 | 04:58 PM
what other engines coudl be able to put out numbers like that( 550-600 rwhp)?
Old Feb 23, 2006 | 05:50 PM
00cls1camaross's Avatar
call victory racing...
Old Feb 23, 2006 | 07:32 PM
Greed4Speed's Avatar
deep pockets
F'n1996Z28SS
Aug 23, 2023 11:19 PM
ChrisFrez
Mar 22, 2015 07:00 PM
MadMav
Feb 6, 2015 11:02 PM
ChrisFrez
Nov 30, 2014 08:41 AM
