What Size Pulley For 10lbs Of Boost,do I Need It Retuned.....
Old Aug 12, 2003 | 05:09 PM
vipermatt's Avatar
Question What Size Pulley For 10lbs Of Boost,do I Need It Retuned.....
I am running 5-7lbs of boost with a aftercooler would like to run 9-10lbs of boost I see 4-5 lbs until 4k rpms and 7lbs about 5500 rpms would like to have 5-6lbs around 3-4k rpms and max out about 9-10lbs what size pulley do I need. I called MTI and ask them if I could run more boost they said yes but I would have to get it retuned first. they dont recommend running more boost without retunning. My motor 9:1 compression ratio. Do you think I could run a little more boost without having it retuned. thanks for any help..
Old Aug 12, 2003 | 06:04 PM
Erik 94TransAm's Avatar
Ask yourself this. Is it worth risking that nice engine and heads on not getting it retuned? Better safe than sorry.
Old Aug 13, 2003 | 07:25 AM
My84Z's Avatar
His engine says it is built so i am assuming 10lbs is not a worry for him.
Old Aug 13, 2003 | 07:28 AM
chpmnsws6's Avatar
tuning still needed....
Old Aug 13, 2003 | 07:52 AM
My84Z's Avatar
yes retune to get the fuel right
Old Aug 13, 2003 | 07:59 AM
chpmnsws6's Avatar
yup. anytime more boost is added, even 1psi you need to retune it...... or so i do in the dsm
HectorM52
Jul 30, 2017 11:46 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
