What mods are best for the LS1
Old Jan 6, 2006 | 01:24 PM
firemblem's Avatar
I am getting a 98-00 LS1 camaro and was wondering what would be the best mods for the car if i want to dramatically increase the rwhp. Lokking to spend around 2-3 thousand
Old Jan 6, 2006 | 02:45 PM
Plague's Avatar
Re: What mods are best for the LS1
Here is some info.
http://www.ls1tech.com/forums/showthread.php?t=213148
http://www.ls1tech.com/forums/showthread.php?t=139142
http://www.ls1tech.com/forums/showthread.php?t=327734
For starters:
Lid
Catback
Long Tubes
LS6 Intake
Cam
I would go in that order.
Old Jan 6, 2006 | 04:11 PM
Greed4Speed's Avatar
A4 or m6?
If its an A4...a converter..hands down
Great mods for both would be good tires and suspension mods. Power means littel if you can't hook.
Best mod of all is the driver mod. Take time to learn your car and how to maximize what you already have.
Old Jan 6, 2006 | 05:22 PM
Plague's Avatar
I did forget the TC if it an auto... very good point.
Old Jan 6, 2006 | 10:55 PM
00ls1's Avatar
the ls1 responds well to both intake and exhaust mods... start with that and go from there... then maybe heads/cam package
Old Jan 6, 2006 | 11:04 PM
CrabhartZ28's Avatar
Once you get LT's, a lid, and your catback out of the way, start spending on drivetrain mods, such as a 12 bolt or 9" rear and a better differential. 3.73 gears are great too, regardless of tranny. Then a stall for an auto and a better clutch or something for the M6.
Then start saving for your heads/cam swap.
Old Jan 7, 2006 | 10:27 AM
teke184's Avatar
since you're new....
i suggest you go through the first 10 pages of the LS1 forum and read alot. most of what you are asking has been covered over and over. as have alot of beginner mods, and which ones are best.
and while you do that, make a list of things you don't understand....then use the SEARCH function
Old Jan 8, 2006 | 10:13 AM
BISHOP's Avatar
Originally Posted by Plague
For starters:
Lid
Catback
Long Tubes
LS6 Intake
Cam
I would bump the cam off and put a dry kit and a set off svo 42lb injectors in. Those two items were good for knocking 1.3 seconds off my car on a stock tune.
If it's an auto I would hold off on getting a rear end untill your in the bottom 11's. I would get an Auburn Pro and get rid off the zexel pos though.
Old Jan 8, 2006 | 10:16 AM
UtOhCop's Avatar
LT's and a wet kit
13qtr
Oct 28, 2016 08:11 PM
1slow93z28
Sep 1, 2015 06:22 PM
Nickster 7
Aug 27, 2015 10:12 PM
Jocofire1
Aug 7, 2015 03:16 PM
CARiD
Jul 7, 2015 08:19 AM
