What Mod Should I Look Into Next For My Ws6
Old Dec 26, 2003 | 04:03 PM
99TransAmWS6's Avatar
My 99's got a spec 3 clutch updated slave and master Corvette FRCs Ground control coil over set up in the front and lowered in the rear , Hotchkis Strut Tower Brace, Adjustable BMR Tubular Panhard Rod, KYB Adjustable shocks, Borla Cat-Back Exhaust, Lou short stick, K&N Filter, NGK Plugs and 8.5 wires.
I was thinking of getting the mccord cut out for the borla..money is kinda tight..i could afford that as of now though.
Old Dec 26, 2003 | 04:14 PM
mcflyz28's Avatar
headers
Old Dec 26, 2003 | 05:33 PM
teke184's Avatar
tsp lid
or a decent shifter, even though you have the lou's...a good shifter will make a big difference. look into SLP's shifter, it's only $100 i think and your lou's will fit it.
how bout some small things like poly torque arm bushing, or maybe poly motor mounts?
Old Dec 27, 2003 | 04:20 AM
TXZ28LS1's Avatar
seems like your suspension is all hooked up. but i would do headers next...
Old Dec 27, 2003 | 07:25 AM
95TealLT1's Avatar
1st - Long Tube Headers
2nd - Cam, springs and pushrods w/programming
Those two modifications would bump you up around 380 rwhp and put you in the low twelve’s in the quarter mile. Add stage 2 heads and you could be in the high eleven’s.
Good luck,
Al
Old Dec 27, 2003 | 12:41 PM
Antz97ZNJ's Avatar
lid and headers
Old Dec 28, 2003 | 12:33 AM
rncotton's Avatar
I didn't see Lower Control Arms in your mod list. I installed boxed LCA's with poly bushings on my WS6 and my 60' time dropped .2
Otherwise, since you say money is a little tight, get your motor to breathe better. Headers! That seems to be the most bang for the buck mod around.
Old Dec 28, 2003 | 03:24 PM
Gloveperson's Avatar
Sub-Frame Connectors, headers, Lower control arms and the brackets, and a lid are all good possible choices. The Suspension seems really good, so I suggest getting a Lid since they are only like 100 dollars (and get a paper filter )
Old Dec 29, 2003 | 01:25 PM
chpmnsws6's Avatar
have you opened up ur ramair intake? there are 2 blockers and the honeycombs stopping air from getting in there. get em out and seal up the box to the hood somehow and you will feel a differance especially on the highway
Old Dec 29, 2003 | 06:57 PM
RS Dragster's Avatar
... and then make sure to have some rain-blockers made, too
HibachiZ28
Nov 6, 2015 12:53 AM
Stephen68
Oct 16, 2015 03:50 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
DelSoto
Sep 19, 2015 05:31 AM
95mysticta
Aug 20, 2015 07:43 PM
