What are good pads and rotors to switch to on 16" rims?
Old Jul 5, 2005 | 10:50 PM
BlazeOne's Avatar
Looking for some opinions on this one. I've got a 2000 Z28 A4 and I'm at my second brake change. I like to keep her factory appearance with the stock rims 16" 245/50. The rotors start to warp near brake change time so I'm toying with the idea of changing rotors. Any opinions on Power Slot or Power Stop rotors, and slotted versus drilled. Also need some opinions on good pads, semi-mettalic or carbon ceramic? Thanks
Old Jul 6, 2005 | 05:29 AM
teke184's Avatar
Re: What are good pads and rotors to switch to on 16" rims?
if you're getting warping...upgrade the rotors.
i would look into the Baer OEM upgrade kits, they come with the 2piece front, one piece rear rotors, and Hawk pads matched to the rotors.
i think thunder racing has them, they or someone else was doing a GP on them recently. kinda pricey but they are good pieces
Old Jul 6, 2005 | 02:32 PM
shouldaboughtthez's Avatar
I am running the IRotors slotted and crossed drilled rotors front and rear. I am using Wagner pads from O'Reilly.
Rotors $300
Pads $80
Old Jul 6, 2005 | 03:40 PM
Greed4Speed's Avatar
Crossdrilled and slotted are driveway jewelry only.
Get some Autozone, Napa, Wagner, or Brembo stock replacements and put some good pads on them and you will stop every bit as good as if you went crossdrilled/slotted.
What you want to look at is the rotor weight and thickness. This is one area where heavier is better. The stockers warp easily because they are light and thin.
I'm running Wagner Thermoquiets. They suck at high speeds and when warm. I do not recommend them at all.
Old Jul 6, 2005 | 04:14 PM
Kataklysm's Avatar
OEM rotors and Hawk pads.
Old Jul 8, 2005 | 06:43 AM
KY98LS1's Avatar
Same here, OEM rotors and Hawk brake pads. Something else must be going on if you are warping rotors. No problems with OEM rotors here.
Old Jul 8, 2005 | 01:16 PM
The problem is far too widespread in GM vehicles to claim it is something else causing the rotors to warp. They're too light & thin. Just over torque a lug or 2 and you have warped rotors on the stockers.
Old Jul 9, 2005 | 10:19 AM
Mikael's Avatar
Autozone rotors, I always liked EBC greenstuff pads.
Old Jul 9, 2005 | 05:56 PM
psychocabbage's Avatar
warping is to be expected with your stock units.. after that, hit up autozone and get the cheap replacements ($40 each).. Its only the fronts that typically warp.
Then just get the cheap pads and VOILA! You have full braking ability. woo hoo..
Slotted rotors = more pad replacements
Crossdrilled rotors = cracked unless they are done well.
Seriously, unless you are into autoX you wont need them and if you are that into AutoX then just go for bigger all around.
Old Jul 10, 2005 | 12:02 AM
BirchMan98z's Avatar
Unless you do serious autocross racing, drilled rotors are nothing but a visual mod. Drilled and/or slotted will chew through brake pads much more quickly also.
Old Jul 10, 2005 | 07:18 AM
Drilled and slotted are nothing but visual if you are into any racing, unless you're doing it for lighter rotors in drag racing.
Larger rotor diameter, vents, and more mass is what you want, not holes or slots.
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Jazsun
Dec 29, 2014 12:14 PM
