what else to do?
Old Jul 15, 2003 | 05:45 PM
hurricaine418's Avatar
what else to do?
have a z28, just dumped in 8k, vortec supercharger w/aftercooler,(and related fuel kit) msd ignition, subframe bars, wider rear tires. any thing else i can do to raise the horsepower without killing the bottom end of the motor? considering cam, but is it worth it? now have 480 bhp (flywheel)
Old Jul 15, 2003 | 07:43 PM
jd13's Avatar
Are those you're only mods? If so, there a ton of things to do.
The first thing I would look at would be suspension. You're gonna need it if you want to put that power to the ground. Some adjustable shocks would do well matched with some springs if you want to go that far. Definatly some lower control arms and relocation brackets if needed.
Headers, you should have those already. Depending on the year of the car, you could upgrade to a LS6 or Holley intake.
Oh, almost forgot. If you run sticky tires with that kind of power, you're gonna blow up your rear end. I'd start looking at some 12 bolts if you plan on visiting the track much.
