what driveshaft do LS1 cars come with
Old Sep 30, 2003 | 05:56 PM
Knowklew's Avatar
I have a 2000 Z automatic and i am confused about what driveshaft my car comes with. Steel or alum.?
Old Sep 30, 2003 | 06:01 PM
Mikael's Avatar
2.73 Cars come with steel. Everything else is aluminum.
If you can select 1st gear, you have aluminum.
Old Sep 30, 2003 | 06:12 PM
2001NBMZ28's Avatar
My car originally came w/2.73's (steel ds) and I could select 1st gear.
Old Sep 30, 2003 | 06:20 PM
Capn Pete's Avatar
Arrow
Mikael, you're thinking about LT1 cars with 3.23's. AFAIK, all LS1 cars have a selectable 1st gear (I know for sure that I can shift into 1st since I've got the A4 w/2.73's). Also, I can confirm having a steel driveshaft, and I agree that the aluminum d.s. comes with 3.23 geared A4's, and also M6's.
Old Sep 30, 2003 | 06:29 PM
99blackSS's Avatar
Look for these codes on the inside of your drivers door, in the door jam.
GU2 = 2.73 gear ratio and 2 piece steel drive shaft
GU5 = 3.23 gear ratio and 1 piece aluminum drive shaft
Old Sep 30, 2003 | 07:05 PM
Capn Pete's Avatar
Question
2 piece driveshaft?? I only see 1 tube?!
Old Sep 30, 2003 | 07:32 PM
99blackSS's Avatar
I stand corrected. I guess only the V6s were two pieces.
Noenav
Mar 1, 2019 07:38 AM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
USAirman93
Nov 24, 2014 03:37 PM
ChrisFrez
Nov 23, 2014 10:33 AM
