What do ya think......
Old Dec 7, 2006 | 04:10 PM
CValliere's Avatar
of the TSP H/C Stage 1.5 w/ Torquer 2 cam? Any good? I'm only looking to get 400hp or so to the tires for the street, but for track I'm adding 100 shot to the mix. I will be doing LT's W/ ORY, Borla CB, full bolton's, 4.10's and a tune.
Old Dec 7, 2006 | 05:27 PM
Greed4Speed's Avatar
For the price difference and with that cam, I'd go ahead and get their 5.3L heads.
Old Dec 7, 2006 | 08:03 PM
CValliere's Avatar
The 1.5's and 2.0 are the 5.3 heads. The 1.0 are the LS6.
Old Dec 8, 2006 | 06:30 AM
teke184's Avatar
the cam alone should put down 400rwhp...i know mine came close and it had alot of bugs.
on a less than ideal tune, a slipping clutch, mis-adjusted throttle cable (only opened 85%) it put down over 380rwhp.
with all those problems fixed except the tune, i'm confident i'm at 400rwhp.
so that cam plus some mild ported heads should easily net you 420rwhp.
Old Dec 8, 2006 | 08:30 AM
CValliere's Avatar
awsome. thats about what i was looking for.
Old Dec 8, 2006 | 07:28 PM
The stage 2.5 then.
Old Dec 10, 2006 | 03:42 PM
1WICKDZ's Avatar
do the LS6 cnc heads, stage 1 is enough
Old Dec 10, 2006 | 09:21 PM
The 2.5 actually flows more with smaller runners. Stage 1 may be enough but the other would be better. Plus you won't have to change the springs or pay extra for the performance valve job like you would on the stage 1.
Look at the cost of the heads too.
After you get the comp valve job (if you want the advertised flow numbers) and PRC springs (which you'll need for that cam) you're looking at $1299 for the LS6 heads.
The stage 2.5 is $1199 and comes with both of those plus larger stainless valves.
Ya, pay $100 more for a lesser ported head because its enough.
Eric@Victory Racing
16
Mar 19, 2010 12:57 AM
Bluovlh8er
Jan 22, 2008 12:21 AM
SteveLT1
Sep 7, 2004 02:21 AM
