What to do for induction???
I am going to do some induction but am undecided what to go with. Im gonna list the 2 choices im considering. Please tell me what u guys think.
LS1 Flow Pac
New from SLP, the "FlowPac" combines our Cold-Air Induction Kit, High-Flow Air-Box Lid, F-Body Smooth Bellows, and K&N Air Filter to create a single, jointly engineered package worth up to 25 horsepower over stock. Save $30 over the cost of purchasing the parts individually!
SSRA Super Sucker Ram Air Kit
The Supersucker is a two piece kit, with a lower piece sliding into the upper, which attaches under the nose. This scoop is about 2 inches tall and 15 inches wide. This becomes a continuous box(scoop) all the way up to the base of the air filter. Supersucker is made of black ABS plastic. This matches the OEM appearance of the car and looks great. Since the Supersucker is plastic it won't heat soak like steel. This will help your car run cooler. Speaking of running hot. If a car runs to hot it loses horsepower. To avoid this problem, beginning at the top near the air filter, the Supersucker angles away from the radiator.
These two are here www.ls1speed.com/catagory.cfm?catagory=induction
Vinny
LS1 Flow Pac
Vinny
Originally posted by LetMeBurnU
Go with LS1 flow pac.
If I were to buy the parts right now for a new car that I had I would get.
TSP lid with re-useable filter and an SSRA.
A bellows isn't worth $50
And build a block plate for the SSRA for when it rains.
RUENUF
Mar 13, 2016 03:37 PM
Cbr02
Aug 24, 2015 07:12 AM
