What is the difference between an LS1 engine and a LS6
Old Oct 3, 2002 | 10:28 PM
02T-Camaro's Avatar
So what it the difference?
Old Oct 3, 2002 | 11:12 PM
Nathan1234's Avatar
Post
If you're comparing 98-00' LS1's, intake manifold, cam, heads ,springs, valves, pistons, and block are different... but not that much, really. The 01-02's use the same block and intake as LS6. Same engine, just slightly beefed up.
Try using the search to find more before posting.
Old Oct 4, 2002 | 03:52 PM
redz_02's Avatar
i believe the main difference is in the heads on the 01-02's, they do have a different mas air though.
Old Oct 4, 2002 | 06:04 PM
SpecForceZ28's Avatar
LS6 is in the Z06, the LS1 is in Z28's and WS6's.
The bottom line: LS6 is more powerful than LS1, but you can always make it equal to an LS6 with a few bolt ons and such
EDIT: forgot to add TransAm, so first sentence should read: LS6's are in the Z06, and the LS1's are in the Z28's and TransAm's, and the WS6's.
Hotrods&Muscle
Feb 18, 2015 06:38 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
