Well this sucks a$$!!
My 99 Trans am died on me the other day. I was driving about 80 and had a sudden loss of power and the SES light started flashing. So I pulled over and the engine was running very rough at about 500 RPM. There was a bad knock from coming from around cylinder #7. We plugged in a scanner, it got no signal from the computer. That led us to think it was a computer problem. Turned out the computer was fine. A compression test showed #7 has zero compression. The rest tested fine. There is no gas in the oil and no smoke coming from the exhaust. What the hell could be wrong? Any suggestions?
Bent valve.................seriously
. It happened a little over a year ago to my dad's truck, and the compression in cylinder 4 was ZERO --- not "a couple pounds" --- zero
. As well, a friend was fixing an intake gasket leak on a 3.1L V6, and by mistake installed the wrong push rods back into their homes (swapped intake for exhaust) on one of the cylinders, and when he started the engine, it was "ticking" really bad. Well, after doing a compression test, he found zero compression in one of the cylinders, and sure enough, after pulling the head back off, found a bent valve and a piston with a valve mark in it
Is your car a standard??
Not to say you can't over-rev an auto, but it's more likely with a stick that the engine over-revved a little causing the valves to float and the piston hit a valve. Sorry to say, but your motor's gotta come apart
.Is your car a standard??
You might have a burned valve.. There is a way you can tell if it is a burnt valve is by taking out the plugs and do another compression test, then try squirting oil in to #7 Cylinder and if it does have compression it is more likely a burnt valve... You have to check and then pull off valve cover and if it is a broken vavle spring, you can get a tool to replace valve spring w/ out having to pull the heads..
I would try the oil trick first.. Though..
I don't know that the oil trick works with valves. That is for worn rings (temporarily fills in the gap). Even with broken rings, you would still get some compression.
Pull a valve cover. I don't think you are going to see much.....maybe if it is a broken spring. I think you broke/burnt a valve, and you won't know unless the head comes off. Not really THAT hard on these cars. Get some bad CNC'd heads and a cam....or just get the valve replaced and consider yourself lucky.....Let us know!
TRS Andrew
Jul 20, 2015 08:24 AM
NewsBot
May 10, 2015 08:10 AM
