waterpump leaking
waterpump leaking
my 2001 camaro z28 has 27k miles and the waterpump is leaking. it looks like it is leaking at the gasket almost. do i replace the pump or just the gaskets? thanks im new to LS1's
Re: waterpump leaking
another one for the waterpump wars, if your waterpump is leaking i doubt its your gasket when your waterpump goes bad there is a tiny little hole on the bottom of it (you cant see it) that drips collant making it real hard to find out where the leak is. just to be sure though you might want to take it to a shop and ask them they will probably say its you waterpump ls1;s are notorios for waterpumps going out..
well i guess i will take it off and inspect it, if its bad i will get a new one. is it ok to use an autozone or similar waterpump? or should i buy a GM one? thanks
oh yeah, can i dirve it for the next couple of days until i change out the pump? thanks again
