water pump?
Old Jun 20, 2003 | 11:49 AM
zman28000's Avatar
water pump?
I've gathered from this board that the water pump takes a dump alot on our cars. So last night, as I got out of my car i heard a repeated drip/fizzle coming from the front of the car. I didn't immediately freak out b/c I had been running cold Defrost all the way home. This morn, I popped the hood and noticed on my inside of my hood that there were water marks (i think it was water) primarily on the side of the hood that the a/c piece was, but were clearly on the other side too. My car has 70000 miles on it and I am unsure that the water pump was changed by the previous owner. If this is the culprit, how hard is an install of a water pump on our LS1's?
Old Jun 20, 2003 | 12:35 PM
ZZed's Avatar
I have 49,000 on mine and I have an intermitent leak from the waterpump. It is either the seal or the vent hole. I stops leaking when the engine is at operating temp. I just keeping an eye on the level. It has not leaked for a week or so.
I have the GM manual for the 2000 F-body. The waterpump change is straight forward. Remove the air cleaner housing, drain the fluid, etc. It does, however, recommend removing the cooliing fans. Possibly for clearence. Hope this helps.
HectorM52
Jul 30, 2017 11:46 AM
Biggiebound
Apr 21, 2015 11:28 PM
KYWes
Apr 15, 2015 07:28 PM
Blood type Z28
Apr 8, 2015 11:34 PM
pologreen97z
Dec 2, 2014 10:42 AM
