Wanting 500 hp
Old Apr 22, 2004 | 09:07 PM
DavidSS's Avatar
Wanting 500 hp
Is there anyway to get 500 rwhp out of a naturally aspirated 98' LS1. I would like it to still be streetable. thanks
David
Old Apr 22, 2004 | 10:20 PM
mullettour's Avatar
"Streetable" is a very subjective term. It is possible to get 500rwhp from a good h/c package on a full bolt on car with a good tune. I don't know if you consider n2o not naturally aspirated, but going that route 500rwhp is very attainable with a good cam on a 100-150 shot.
Old Apr 22, 2004 | 10:49 PM
chuck's Avatar
That is going to be basically impossible with stock cubes. Build a good 396+ stroker with good heads and a big cam and it can crack 500rwhp. As stated, streetable is subjective.
Old Apr 23, 2004 | 05:42 PM
RS Dragster's Avatar
Another vote for a stroker!!!
It'll be next to impossible to do without.
Old Apr 23, 2004 | 09:22 PM
DanBUCF's Avatar
I think it would be possible...I know that somebody made just over 450 RWHP with Thunder Racing's T-Rex cam on a full bolt on car. Stock heads though. I think w/the right heads and a tune, hitting the 500 mark shouldn't an issue. As for streetability, thats a whole other story.
Old Apr 23, 2004 | 10:08 PM
96SFLZ's Avatar
Why does it have to be N/A? Just curious.
500rwhp is 500rwhp no matter how you make it. Bolt-ons + a nice (not too big...read: streetable) cam...and spray the sumb*tch. You should be looking at 500rwhp easily and probably close to 600rwtq, maybe more (N2O makes mucho tq).
Trying to do this N/A would be pretty expensive...and you want to keep it streetable so that makes it an even more difficult.
A 427 stroker could/probably would get you there (and might still be pretty streetable) but now you're talking a total price of around $15-20k. You'd most likely be able to do it for cheaper but if you have the local "Eddie's Engines" build it, I dunno if they'd stand behind their work.
Old Jun 30, 2004 | 11:18 PM
ghettosmurf's Avatar
you could get 450 real easy...just get MTI stage 2 heads, X1 cam, UD pulley, headers, lid, and your good to go.
Old Jul 2, 2004 | 07:53 AM
Demon SS's Avatar
while 500rwhp on a stock bottom end is not impossible it would be very tough to do naturally aspriated. one of our project cars is making about 460ish or so, maybe a little more haven't dyno'd yet, but the car runs low 11's at 122mph. trap speed and weight (3300lb race weight) calculations put the car at 468rwhp using
hp=(mph/234)cubed xweight there are other formulas and some put it higher than 468rwhp
the setup is FFHP stage 2 5.3L heads, FFHP Annihilator cam, Dynatech Race headers, LS6 intake, SPEC stage 5 clutch, Moser 12bolt w/spool and 4.11's, Ed Wright tuning(mail order) and we are running about 12.2:1 compression. Stock bottom end.
We run an open exhaust so most would not consider this a "streetable" setup, so if you added a good full exhaust you might loose 10-15hp.
Give us a call we can talk to you about your goals and help you get there, but it won't be easy or cheap.
Old Jul 2, 2004 | 07:25 PM
dug's Avatar
dug
orrrr you can just put a turbo on it
Old Jul 2, 2004 | 07:37 PM
SLPZ28's Avatar
my .2cents i have a 02 with all bolt ons but pulleys, stock heads and a 224/228 581/589 comp cam and I'm around 385RWHP to me that enough driving around the street around 440 @ the motor. But day to day driving I don't use anymore then half of that
Old Jul 5, 2004 | 10:23 AM
HeavyChevySS's Avatar
I agree ! I am right there with you on the HP #s. My velle ran 12.4 @109 mph which calculates to 390 RWHP or 450 CHP.
What did your car run in the 1/4?
Heavy
chstitans42
May 1, 2015 01:03 PM
94Form
Feb 10, 2015 11:23 PM
97TA-WS6-Con
Feb 1, 2015 01:14 PM
InfernalVortex
Jan 17, 2015 09:35 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
