Vibration after water pump install
Old Dec 6, 2007 | 05:15 PM
RxNupe's Avatar
After installing my water pump, i now have a very slight whobble or vibration at low rpms (~2000 or so). It goes away at higher rpms. Any takers?
Old Dec 6, 2007 | 08:47 PM
mrmint69's Avatar
Check your connections on the opti and see if they are all tight and on right.
Old Dec 6, 2007 | 09:39 PM
RxNupe's Avatar
The problem is occuring on my 02 WS6.
Old Dec 7, 2007 | 02:58 AM
MasterZ28's Avatar
What kind of water pump did you get?
Old Dec 7, 2007 | 03:36 PM
RxNupe's Avatar
AC Delco stock replacement
Old Dec 12, 2007 | 07:06 PM
Kwiksilverz28's Avatar
Look at the pulley. Is it straight when turning? Did you screw up any other pulley?
Old Dec 15, 2007 | 03:51 PM
DaddySS's Avatar
Did you put on just a pump? New belts? Anything else?
Old Dec 15, 2007 | 09:44 PM
RxNupe's Avatar
I went ahead and changed both belts at the same time. Bad serpentine belts perhaps? Is there any special process?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
pologreen97z
Dec 2, 2014 10:42 AM
