VERY nasty LS1-Based Race Motor:
Old Jan 20, 2007 | 12:48 PM
Kraest's Avatar
Retired
Actually, it's a C5R Alumium 427ci with C5R heads, but you get the point.
Build here in the dirty south by you know who..........
None other than FMS
854/581 @ 8400 RPM all motor on an engine dyno
Just got finished doing the first dyno session on a customers 427ci C5R setup. We will be testing a few intake designs\changes and cams to get it were we want it but not a bad start.
Final numbers from first session:
RPM C-TQ C-HP
6300 552.7 662.9
6400 561.5 684.2
6500 565.1 699.3
6600 567.3 712.9
6700 576.8 735.8
6800 576.0 745.7
6900 574.9 755.3
7000 580.9 774.2
7100 573.6 775.4
7200 573.8 786.6
7300 567.6 788.9
7400 565.8 797.2
7500 559.8 794.8
7600 557.3 806.5
7700 552.2 809.5
7800 547.7 813.5
7900 548.7 825.4
8000 543.6 827.9
8100 538.8 831.0
8200 537.0 838.3
8300 535.8 846.7
8400 534.2 854.3
8500 525.4 850.3
8600 513.6 841.0
Specs:
-4.125" C5R block
-Callies 4.00" lightweight crank
-Manley billet steel rods
-Custom Diamond pistons 16.1 CR
-Dailey dry sump pump and pan
-Jesel belt drive and .937" lifters
-Custom FMS cam 28x\30x .921"\.880" 114 LSA
-Meaux racing ported C5R heads 4xx intake CFM
-Manley tit valves,Nextek 1.647" springs and tit retainers
-Jesel 1.85 Mohawk rockers
-Beck intake w\105mm T\B and 96lb injectors
-Custom FMS 2.125"-2.25" stepped stainless headers
VIDEO
http://video.ls1tech.com/video/ae185...0d018541ab.htm
This was all done on break in oil,no synthetic oil wihcih is good for 15-20 HP and Meaux's dyno is a conservative dyno.
Old Jan 20, 2007 | 01:32 PM
skifast87's Avatar
that is sickkkkkkkkkkkkkkkkkkkkkkkkkkk. Whats that going in?
awsome awsome awsome
Old Jan 20, 2007 | 02:20 PM
myslowcamaro's Avatar
very nice. that yours or someone you know?
Old Jan 20, 2007 | 05:10 PM
teke184's Avatar
almost an inch of lift!!!!
DAMN
Old Jan 20, 2007 | 11:24 PM
Plague's Avatar
things sounds like a damn top fuel dragster!!!
WOW
Old Jan 21, 2007 | 09:41 AM
AL SS590 M6's Avatar
Moderator
All it takes is money.
Old Jan 21, 2007 | 10:32 AM
Kraest's Avatar
Retired
Wrong.
I've seen plenty of stroker motor cars that only put down 450 rwhp with premium parts put in it and I've seen plenty of low-dollar setups like AIs setup that put down 500+ rwhp through a 383 LT1.
Mike
Old Jan 21, 2007 | 04:17 PM
2000GTP's Avatar
Very nice.
Old Jan 21, 2007 | 06:30 PM
Need4Camaro's Avatar
I think I'm ganna need a new SET of underwear...
I'm curious... 800 HP @ 8K Rpms yet the tourque curve looks relatively flat... I know this is because HP increases as RPMS increase even if tourque slightly decreases... My question is between 6,300 RPMS and 8,600 RPMS ...Would the car continue to pull and if so, would there be any advantage of having 500 Lbs TQ at 8,600 RPMS as opposed to 6,300 RPMS??
I'll clarify alittle better, The tourque remains at around 500 lbs between 6.300 and 8.600 RPMS... What I'm asking is would there by any signifficant advantage of shifting this particular engine at 8,600 RPMS (Higher RPMS) as opposed to 6,300 RPMS (Lower RPMS) when you've reached your peak tourque?...
Old Jan 21, 2007 | 07:20 PM
Kraest's Avatar
Retired
Yeah, because you shift right after peak horsepower, not peak torque. If that was the case, you'd shift a stock LS1 at 4200 rpm.
Mike
Old Jan 22, 2007 | 08:41 AM
Moderator
Originally Posted by Kraest
Wrong.
Mike
Go back and look at the parts list that you posted. That's no budget build, way over anything I coud come up with without a second mortgage.
And I never said that people don't waste money on the wrong parts.
So defensive
Old Jan 22, 2007 | 10:55 AM
Chris@NitroDaves's Avatar
Very Nice thats one nasty combo.
-Chris
Old Jan 22, 2007 | 10:58 AM
bombebomb's Avatar
How long can a 427 last spinning that fast.
Its a beast lol
Old Jan 22, 2007 | 07:24 PM
Kraest's Avatar
Retired
So defensive
Who said it was a budget build? That's a $25-30k motor
Old Jan 22, 2007 | 07:42 PM
Kwiksilverz28's Avatar
My XTerra. It needed some more power. Hard to merge onto the expressway was driving me nuts.
