underdrive pullies yes or no?
Old Nov 18, 2004 | 03:47 AM
  #16
AL SS590 M6's Avatar
Moderator
Re: underdrive pullies yes or no?
Originally Posted by BlueRave
Would installing an underdrive pulley affect the AC, water pump, or power steering? Would the expected life of said components be shorter as a result of the installation? Thanks!
Underdrive would make the accessories turn slower which could make them last longer if anything.
Old Nov 18, 2004 | 03:55 AM
  #17
BirchMan98z's Avatar
the motor DOES rev up a little quicker, could be due to a number of things... For one the pulley weighs less than the stock crank pulley, so that's less of strain on the crank... bad for bored engines though.
Old Nov 18, 2004 | 08:38 AM
  #18
BlueRave's Avatar
If the life of the water pump, ac, power steering components is not affected, what about their performance? Would the car run hotter? Would the AC not be as cold or blow as hard? Would the steering wheel be harder to turn? Thank you very much for your time!
Old Nov 18, 2004 | 04:21 PM
  #19
Michael Ozorowsky's Avatar
Blue: It's running good with underdrives, don't know if I really notice a difference, I think the motor does rev up a little quicker like everyone is saying. Also, ac is cold as ever, power steering is fine. Only prob. i have is when I'm running my AC, Scan tool, and stereo at the same time, batterie goes low, and if I shut car off, need a jump, so to avoid this, when I'm scanning I leave ac off and radio off. THen as long as I'm not tuning my ECM, I can do whatever as normal.
Slayer
Aug 17, 2015 03:55 PM
colts0455
Jul 7, 2015 07:19 PM
T-REX
Sep 1, 2002 02:28 PM
BlowBye
3rd Gen / L98 Engine Tech
24
Jul 22, 2002 07:56 AM
