underdrive pulley and lightweight battery?
I just got an ASP pulley (not installed yet), and want to see if anybody on here has a UD pulley and running a lightweight battery. My car is an auto but would put it in neutral when stopped. I was thinking about getting a hawker genesis gp26 that is 10-12 lbs lighter. Thanks.
thanks AL SS590 M6,I'll go with the lighter battery. I know I am not going to feel anything from the 15 lbs less but I bet I would feel the 100+ lbs I will have taken off total after this battery which is a good .10-.15sec. Also I want to get it closer to 50/50 and mount it in the rear. Maybe a k-member, headers, and a-arms in the future.
Can't put the little battery in the rear. Too much cable required to get back to the front will eat up all your power.
Little battery in front.
Or normal battery in the rear.
http://www.gotbatteries.com/Productp...ctNum=37L107S2
this is the battery I am going to get. Its about 12 Lbs lighter than the one I have now, Is it strong enough for it be mounted in the back or still too much voltage drop? thanks.
sleeperZ96BT
Sep 9, 2015 08:28 AM
