Trapped in 2.0+ 60' time
Old Nov 16, 2002 | 09:44 PM
mdw9965's Avatar
I have Nitto DR's and I can't seem to get a good hook up. I usually run the tire pressure at 20psi. Do I need to be much lower to get these tires to work? Is the BFG drag radial a better choice for traction?
Old Nov 16, 2002 | 09:49 PM
My84Z's Avatar
i have nitto's on the new car and believe me th bf goodrich's are alot better! just bf's are not an everyday tire get some bf's on extra rims you'll be golden 255 50 16 on slad shooters would be the cheap way out.
Old Nov 16, 2002 | 09:51 PM
My84Z's Avatar
i just noticed you got a 12 bolt screw that get some micky thompson et streets and go to town they are pretty close to rinkle slinks
Old Nov 17, 2002 | 01:55 AM
toykilla's Avatar
Honestly, I don't think Nitto's are worth ****. I had a set of them and the tread wore faster than any tire i've ever used. I kinda like Falken's but that's just me and I hear they don't make them anymore.
Old Nov 17, 2002 | 05:01 AM
redz_02's Avatar
Get some et streets, they will drop it, just be carful on that 10 bolt. I think go drag or go street, drag radials are that inbetween mark.
Old Nov 17, 2002 | 05:04 AM
redz_02's Avatar
ok, so you do have a 12 bolt, get some slicks, that is the whole reason for upgrading your rear, then luanch off the rev limiter . Hell add a hundred shot and you got mid 11's.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
