Traction Control
Old Jun 13, 2002 | 11:49 AM
Scott McDonald's Avatar
Post Traction Control
What are the pros and cons of the traction control option on the Camaro? Anyone that has it, have you had any trouble with it?
Old Jun 13, 2002 | 12:28 PM
NEWBIE T/A's Avatar
Lightbulb
I did not buy one Camaro because it did not have it !!
My T/A & the SS both had/have it - at least once on the SS it kept me from doing a slide around a corner - well, an unintentional slide !!
As you can guess, I am very much "PRO" T/C.
If you don't like it, you can always turn it off , or convert it to default to off automatically.
And, as far as I know, if it breaks it causes no trouble other than perhaps an annoying trouble light on the dash.
My .02 -
NEXT !
Britt
'99 T/A
Best 13.071 @ 104.92
Now own '99 SS # 2073 !
12.969 @ 105.44
Old Jun 13, 2002 | 04:09 PM
XKnightRider's Avatar
Talking
I didn't have it on my '97 LT1, but there were times(in the rain) when I really wished I did. On my LS1 I ordered it with ASR. It has saved me a few times already. You just have to remember to turn it off when you race. I now have an SLP ASR reverser. Now I can turn it on when I need it.
The only draw back is the money you spend for it and I know on the LT1's you had to relocate it if you wanted to install a supercharger, not sure if that's true on the LS1.
2002 Camaro SS #3586 6M Sebring Silver, T-top, Billet Grille, Hurst shifter, !CAGS, Whisper CF Lid, Holly PowerShot filter, Corsa Catback w/full polish tips, 160 Thermo, SLP fan switch, ASR reverser, TA axle cover w/stud kit, MAFT.
Waiting to install: NX wet kit, Hotchkis STB, LCA's, APHR.
Baseline Dyno: 317.9RWHP 335.9RWTQ with MAF ends only: 325.6RWHP 350RWTQ. (Stock)1st 1/4 mile 13.46 @106.9 2.23-60'
new best 13.306 @107.89 2.12 60'
http://community.webshots.com/user/xknightrider
4-sale MAF ends....going to N02 so need to ditch them.
Old Jun 13, 2002 | 05:25 PM
WhoBetter?'s Avatar
Post
well it was raining today and with an ls1 you can easily spin tires at 1500 rpm so it wen't off like 10 times today on the way home, it's good but if there was a f-bod that i really wanted i wouldn't turn it down just because it didn't have it.
Old Jun 13, 2002 | 05:30 PM
Hot Pastrami's Avatar
Post
I've tried mine on and off in different weather conditions, and I've found that I prefer to just turn it off all the time. In snow/ice it's worthless, and in the rain I just drive like a sane person and the TC isn't really necessary. But if you're the type to do thingss nailing the gas making a left turn, then traction control may be for you.
It's just one of those things that some people will like and others won't though.
Hot Pastrami!
Onyx Black 2000 SS M6
!CAGS
Flowmaster
Direct-Flo Lid
4.10 gears
Z06 clutch
Hypertech Power Programmer
NEXT: Cutout, Ported MAF
Old Jun 14, 2002 | 10:05 AM
ScottZ's Avatar
Post
I too drive with the ASR off. I hate it. It will bog the engine to the point of stalling when there is no traction (Ice/Snow). If it were less obtrusive, it may be ok, but it is a primitive system that is either on or off.
I can think of other places to put $450.
My .02.
Scott
1997 Z28 MM6 Moroso CAI, Flomaster American Thunder, Taylor, Air Foil, SLP Headers, Crane Ignition, MAF, HPPIII, 4:10's, Summit Girdle, Drilled Rotors,
13.75@ 100.98 MPH
2.055 60'
No New Times With Gears....yet.
Old Jun 14, 2002 | 04:03 PM
96fbirdA4's Avatar
Post
If you're going to buy an Automatic, definetly get it.
- Steve - 1998 Pontiac Firebird Trans Am
LS1 A4, 2.73's, Kumho Ecsta Supra 712 245/50/ZR16's, Direct Flow Lid, GMAF, !FRA, Loudmouth, 3" Y-Pipe, AIT Mod
13.8 @ 103, 97+ RPO Codes, Join The CamaroZ28.Com Users Webring
Old Jun 14, 2002 | 05:05 PM
zeropt99's Avatar
Post
I've got it, and although I must say, if you drive like a sane person, you don't usually need it...but there are times when you want it, and it makes your drive much safer when you have it!
It's saved my butt a time or two from looking like an *** and sliding around at an intersection.
Pewter 1999 Z28 M6
Loaded, power everything, t-tops, leather, chrome wheels
Aftermarket stereo system.
adam@adamkirk.com
http://www.adamkirk.com
Old Jun 14, 2002 | 07:37 PM
Out2HuntU's Avatar
Post
how come you have to turn off T/C when you race? how does it slow you down?? I'm new at this so I don't understand things very well. thanks.
-Nelson-
Old Jun 14, 2002 | 08:36 PM
96z's Avatar
96z
Post
<font face="Verdana, Arial" size="2">Originally posted by Out2HuntU:
-Nelson-
</font>
It slows you down because once its activated its almost like someone pushing the gas pedal against your foot....the more your wheel spin and the harder you push the more you go nowhere. Its because the engine pulls timing once its activated. Pulled timing equals less power.
96 black Z28 A4
GTP stage II heads, GTP 226/230 cam, 11:1 CR, Pro Torque 2800 TC, Tranny cooler, 3.42, 1.6 rr, Holley 58mm TB, Hooker LT's, SLP CAI, cutout, Flowmaster, Wolfe cage, Carrera's, 5 point belts
Mattucci Motorsports WNYFA FLFB
Pics Anybody else need earplugs when they drive????
Old Jun 14, 2002 | 09:18 PM
Out2HuntU's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by 96z:
</font>
Got it. Thanks man.
Not Fbody yet.
Old Jun 15, 2002 | 09:09 AM
Jon657's Avatar
Post
I think its too "touchy". It seems like its always kicking in when there is only slight spin. Personally, I would rather it just let go a little bit without the accompanying "bog" down that comes after. I turn mine off quite often
Old Jun 15, 2002 | 06:35 PM
96z's Avatar
96z
Post
No problem. Mine is always off and in my opinion uneeded, if you feel or hear a little wheel spin......take you foot off the pedal.
96 black Z28 A4
Old Jun 16, 2002 | 08:04 AM
Jon657's Avatar
Post
Okay, I totally recant what I just said. Im not going to give all the details but it involves an intersection, rain, a little excessive throttle, lots of sliding, a curb and lots of grass (the kind you plant in public intersections). Im still keeping that ASR off when its dry though.
IndyZman
Oct 22, 2015 02:17 PM
PopoFormula
Oct 12, 2015 04:19 PM
Louey
Pacific
Oct 1, 2015 12:37 AM
Stephen68
Parts Wanted
Sep 27, 2015 06:42 PM
drt
Sep 27, 2015 04:39 PM
