Tracking down thud after lowering
Old May 7, 2003 | 07:39 PM
Jason Novak's Avatar
I've just lowered my camaro about 1.5" with DMS springs and installed lca brackets and subframes. Sometimes when I get one the gas hard after a second or two there is a loud thud in the back. It almost sounds hollow like the subframes or exhaust, but I'm going in a straight line for it shouldn't be a ground clearance issue, and there seems to be a lot of clearance on the exhaust (loudmouth). I don't really see any signs yet of where the contact may be coming from. Does anyone have any suggestions what could make contact under hard acceleration?
Old May 7, 2003 | 07:45 PM
stik6shift98's Avatar
shocks could be bad
Old May 7, 2003 | 07:48 PM
I hope not ... put in new bilstein HD's when I did the springs, guess it could have been bad from the factory
Old May 7, 2003 | 07:57 PM
My84Z's Avatar
could be the tranny mount as the supension is still and has less give.
Old May 8, 2003 | 03:35 AM
sleeperZragtop's Avatar
Were the Bill's re-valved to work with the shorter springs?
Old May 8, 2003 | 12:48 PM
Aklaim's Avatar
Id put money its your torque arm hitting the underside of the car. I've seen this happen a lot on 3rd gens, and the rear end on a 4th gen is identical.....look into it.
Old May 8, 2003 | 01:19 PM
They weren't revalved but from everything I've read they should work stock. Or at least I haven't heard of similar problems
Old May 8, 2003 | 02:20 PM
hmmmm...maybe...but still they may leak
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Feffman
Jul 2, 2015 06:52 AM
HectorM52
Jan 31, 2015 07:29 PM
