Is the timing right?
Old Jul 5, 2004 | 03:34 PM
Snowmann's Avatar
@ WOT in 2nd gear im running about 22 degrees timing, does anyone know for sure what it should be running? I never checked it before the converter so I dont know if this is normal or not. Seems to low, intake temp was low 80s and coolant temp is about 195. If it is low, why, something to do with the converter possible. Or TM with the converter. If so can PCM4less fix it?
Old Jul 8, 2004 | 03:52 PM
Snowmann's Avatar
ttt
Old Jul 10, 2004 | 03:22 PM
Snowmann's Avatar
Knowbody knows? what is the timing set on the cars running with LS1 edit?
Old Jul 10, 2004 | 11:57 PM
Meccadeth's Avatar
Try checking LS1tech.com ... You'll get a lot more answers over there.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
