The time has come...how do I replace my EGR valve?
Old Aug 30, 2004 | 02:24 PM
Meccadeth's Avatar
I finally have some expendable money that I can use on this. Where can I find a replacement EGR valve and how do I reinstall it? Is there anything else I will need? (I've alreaddy got a new O-ring) Like a new EGR tube or gaskets or anything like that?
Old Aug 30, 2004 | 05:29 PM
bombd84's Avatar
Re: The time has come...how do I replace my EGR valve?
May I ask why you are doing this??
Old Aug 30, 2004 | 06:32 PM
Greed4Speed's Avatar
Here ya go:
Pull the EGR and AIR pump out. Block off the openings for them (I have some made from aluminum plating I picked up from Home Depot and use a freeze plug for the intake) and go to a tuner and pay $50 to get the codes turned off. Thats all you'd need.
Old Aug 31, 2004 | 01:52 AM
Meccadeth's Avatar
I don't want them deleted, I just want the EGR replaced. Until I can get some LS6 heads, I am going to keep them. Why? So I'm not polluting anymore than I need to. Its not worth the extra 1/2 horsepower and 2 lbs of weight I'll save.
I'm doing this because my SES light came on and they linked it to a fualty EGR valve at autozone...
So does anyone actually know how I can replace them?
Old Aug 31, 2004 | 04:54 AM
AL SS590 M6's Avatar
Moderator
EGR is easy on an LS1 f-body. Any parts house should have a replacement EGR. 2 bolts on the flange, the tube and the electrical connection. And it's right out front instead of buried in behind the intake like on an LT1. Just get a new gasket. (check in the box first there might be one in there).
Old Sep 1, 2004 | 06:23 PM
Meccadeth's Avatar
Holy crap! Thank you!
This is the first serious response I've had on here and LS1tech.com in my 3 attempts Thanks a ton dude.
Old Sep 3, 2004 | 06:19 PM
Since 01's and 02's don't even have EGRs, I don't see any plroblem with polluting more w/out it.
Old Sep 5, 2004 | 06:24 PM
BirchMan98z's Avatar
Yeah, I passed the sniffer way way way under their "acceptable" ratings, and I haven't had egr or air for a long time--- and I'm not exactly stock.
Old Sep 6, 2004 | 11:02 AM
Bone Maro's Avatar
I have my stocker if you need one. Make an offer.
HectorM52
Jul 30, 2017 11:46 AM
jocamino
Dec 29, 2014 10:15 PM
Jazsun
Dec 29, 2014 12:14 PM
