Time to change speedometer detting?
Old Mar 30, 2005 | 02:12 PM
gearslammer's Avatar
I am goiung from stock 02 tires and rims to 275 with 17in' rims. Because of the lower profile can I get away without changing the speedometer or does it need to be done to be accurate? If so, is it a matter of reflashing the PCM or is it mechanically related?
Old Mar 30, 2005 | 02:57 PM
2001NBMZ28's Avatar
Re: Time to change speedometer detting?
If you're going to 275/40-17's you won't need to change the speedo, the diameter is about the same. Speedo changes have to be made through the PCM.
Old Mar 30, 2005 | 03:29 PM
Thanks bro.
sdn1997rs
Dec 30, 2014 08:30 AM
Jul 4, 2005 05:00 PM
guionM
15
Aug 3, 2002 04:08 PM
2K1SunsetSS
Jun 21, 2002 02:13 PM
