Ticking after gettting on it hard.
Old Sep 5, 2008 | 07:47 AM
crazytglo's Avatar
Ok first off about 2 months ago I missed a 3rd to 4th shift hit 2nd and bent a valve. I tore down the passenger side head and replaced the valve and noticed a small tick at first and turned out to be on the driver side (used the hollow pipe to ear method) after I added some Lucus seemed to clear up for a while.
Well today when I got on it and went from 1st to 2nd chirped the tires and got off of it and then like 3 seconds later I heard a terrible ticking and smelt gas really bad!
Could it be a sticky lifter or what? Thanks in advance for the help!
Old Sep 5, 2008 | 09:34 AM
Lunch Box's Avatar
I'm thinking that an additive wouldn't have solved your problem, at best just covered it up for a while. But that's just my thinking
Old Sep 5, 2008 | 10:21 AM
crazytglo's Avatar
Well as soon it started it stopped like a couple minutes later. Thats why we thought it might be a sticking lifter, any ideas?
Old Sep 7, 2008 | 05:40 PM
Kraest's Avatar
Retired
Lucas is garbage.
Anyway, you're going to have to try and isolate the problem by once again checking the valvetrain. If you have aftermarket rockers (very bad idea unless you're going with a shaft rocker setup and a high $$$ high horsepower motor), recheck them and check the springs for any breakage.
Mike
Daluchman1974
Sep 11, 2015 06:12 AM
1slow93z28
Sep 1, 2015 06:22 PM
Cam's maro
Aug 11, 2015 07:45 AM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
