tick tick tick
Old Jun 7, 2003 | 10:51 PM
2000zee28's Avatar
tick tick tick
I need a little advice. My last car was a 6.6L T/A so I may be talking old school mechanic stuff. I bought my 2000 Z28 6 months ago. I have a lifter/rocker arm tick on the driver side.
It comes and goes. Is there arm rocker arm torque spec for the
roller rockers? I would like to open it up and set them.
Old Jun 7, 2003 | 11:49 PM
norcalstreet's Avatar
You sure it's not an exhaust leak? An exhaust leak may go away as the car heats up. The heat causing the metal to expand and seal the hole while hot.
Old Jun 8, 2003 | 12:19 AM
2000zee28's Avatar
I think I have a lifter tick but a exhaust manifold leak would be alot easier to fix. Are LS1's (stock manifolds) prone to exhaust leak? Anyone no the torque spec for the manifolds? Thanks Ron
Old Jun 8, 2003 | 02:12 PM
BadAndy743's Avatar
It can also be caused by leaking gaskets in the A.I.R. fitting right next to the manifolds. They are kind of finicky. Mine are ticking a bit right now, because I disconnected them to swap the plugs. didn't get away with it . But i've ordered new gaskets for next week. Should fix it right up.
Bad Andy
Old Jun 8, 2003 | 03:02 PM
2000zee28's Avatar
Hey guys thanks for the help. The driver side exhaust manifold had a small leak. I could see black soot on the head around #1 and #3 cyl. That's was alot eaiser to fix then my rocker arm ticking tear down. Thanks for saving me the work. If your in the DFW area "I owe ya"ll a beer"
1slow93z28
Sep 1, 2015 06:22 PM
94Z28LS1toLT1
Apr 30, 2015 05:19 PM
importkiller94
Jan 17, 2015 09:03 PM
sc93
Apr 4, 2003 02:47 PM
Chris91Z
Mar 25, 2003 02:24 PM
