Throttle cable
Hey guys,
I was looking under the hood today(damn engine detailing!) and I saw that mythrottle cable appeared to be entirely to loose. Is it supposed to look that way on LS1s? How can I tighten that up? 2000 SS
Thanx
BadAndy
Thanx
BadAndy
Are you getting WOT when you floor the pedal? That's all that matters. Just check to make sure that the throttle body arm is going all the way to the stop when you floor it. If so then you have no worries.
Sorry, I don't know how to adjust the cable. I don't think it is and you would have to buy a new cable but I'm not 100% sure.
Bart A Lane
fans@1coolpc.com
2002 Camaro Z28 M6
K&N, SLP Lid & Ram Air, ASP Pulley, Pace MAF, TR55, Thundervolts, FLP Headers, Corsa Cat-Back, Eradispeed Rotors, Braided Lines, Castrol SRF Fluid, Carbon-Kevlar Pads, 17" 10 Spoke SS Wheels.
Bart A Lane
fans@1coolpc.com
2002 Camaro Z28 M6
You can adjust it on some models rather easily - on others, you can't really (and it can differ from A4 to M6). I know on the 2000 model A4 there is a small black cover along the throttle cable two feet back from the TB itself. The cover can be removed (pried off easily) and inside is a tension coil. You can adjust this to tighten the cable. When the cover goes back on, it holds the coil in place.
Don't tighten too much or else the TB you not close fully when you foot is off the gas. Some guys have tied knots in the cable to tighten it, but I don't recommend that.
2000 Pewter SS #C161
SLP Dual-Dual, Bilstein suspension, Eibachs, 21mm/35mm swaybars, GMAF
SLP CAI w/lower plate, !EGR, Direct-Flo, SLP STB, Ported TB, ASP Crank pulley
SLP/AAM Differential cover, SLP 2600, Powershot, MSD wires, NGK's,
BMR Boxed LCAs, BMR PHB, G2 DSL, Heavy Lead Foot...
http://community.webshots.com/user/murlynd
Right,
I ve Got the M6 T56. I mean it still hauls *** when I put my foot down, but if the cable were tighter then I would get a better(quicker) response from the pedal input. I understand that it should not be too tight, I just want it taut when the throttle is off.
BadAndy
BadAndy
Aug 24, 2015 06:41 AM
detroitmuscle
Jul 31, 2015 04:21 AM
88IROC_Z
Jul 22, 2015 11:38 PM
