Throttle Body that good?
Old Oct 20, 2004 | 04:12 PM
Blue02z28's Avatar
Hey guys, with all of the mods I have done already, would a 80mm throttle body help me that much? How good is the stock Intake I already have? I know the torque converter took away from the top end of my car, so how much would this help me mid-top range? Will a throttle body help me pull a lot better from 50- even with an auto? Thanks
Old Oct 20, 2004 | 06:16 PM
rwb's Avatar
rwb
Re: Throttle Body that good?
A TB won't help, your stock is more than good enough for what you have. As for the intake, it is an LS6 intake.
Old Oct 20, 2004 | 06:17 PM
95GRNZ's Avatar
From what I have read and heard is that stock TB can handle quite a lot of hp over stock, so changing it might not be too beneficial for you.
I'm sure somebody with more insight will correct me if I'm wrong with my conclusions.
TS
Old Oct 20, 2004 | 06:36 PM
Blue02z28's Avatar
then why is it that I have always been told that all the new camaros need is a good throttle body to let more air in? also, a guy with only a new throttle body absolutely flew by me the other night on top end.....
Old Oct 20, 2004 | 07:08 PM
Antz97ZNJ's Avatar
waste of money for sure, your stock one is just fine
Old Oct 20, 2004 | 07:54 PM
rwb's Avatar
rwb
Get some tuning done on it, then it will fly.
Old Oct 20, 2004 | 08:57 PM
Flat_Tire_'s Avatar
Don't bother getting a new throttle body unless / until you get a larger cam.
Old Oct 20, 2004 | 09:28 PM
Blue02z28's Avatar
Exclamation Re: Throttle Body that good?
so what would be the next thing you all would do? seems like I have all I need with exhaust work, anything else with intake.. or what?
Old Oct 20, 2004 | 09:40 PM
V6toZ28's Avatar
You have a 75mm mouth on the intake ... putting a 80mm TB in front of it will do you no good.
Old Oct 21, 2004 | 04:43 AM
AL SS590 M6's Avatar
Moderator
Lid and SSRA??
Old Oct 21, 2004 | 03:56 PM
BirchMan98z's Avatar
if anything I'd recommend a ported stock throttle body. They can handle plenty of power in stock trim, and a ported stock TB will also be good for a bunch of ponies at the rear wheels. Once you start getting upwards of 425-450 rwhp, then it might be time for a higher flowing TB... but all an 80mm will do for you is slow you down, and pedal pressure will be way stiffer on the gas.
Old Oct 21, 2004 | 03:59 PM
ROADRAGE's Avatar
I think you may be thinking airlid. THOSE will help. throttlebody isnt going to do anything for you yet.
Old Oct 21, 2004 | 05:16 PM
rwb's Avatar
rwb
The stock TB is good for over 700hp at the tires. Rob R. at QMP did that with a stock TB. I'm over 550hp at the tires with my stock TB. It will just be a waste of money.
Old Oct 21, 2004 | 05:19 PM
Blue02z28's Avatar
so you all are saying an air lid (SLP???) and a K&N filter? will that help out my top end that much? would a MAF be worth it?
Old Oct 21, 2004 | 06:04 PM
Blue02z28's Avatar
also, do you think the Flowpac from SLP for 269.99 is worth it??
