Testing an Idle Air Control Valve
Anyone know how to test the idle air control valve? I have a friend that just bought a 99 trans am. His car has a random misfire on almost all cylinders. He had a weak #8 coil pack and changed it but the car still runs really rough. He thinks the idle air control valve might be the problem because he read that if you pull the connector while running there should be a change in idle. His doesn't change.
Anyone know the testing procedure?
Matt
Matt
F'n1996Z28SS
Aug 23, 2023 11:19 PM
95chwagon
Jan 13, 2015 09:19 PM
