Supercharger just installed
Old Nov 19, 2002 | 10:05 AM
  #16
V6toZ28's Avatar
Originally posted by robvas
350hp will run you mid-11's with traction....
No mid 12s is about right on a 430 supercharged LS1 ... the operative word being traction, they generally have a hell of time grabing traction consistantly. You may see the occasional 11 second run, but for the most part they're spinning all over the place ...
Old Nov 19, 2002 | 10:09 AM
  #17
My84Z's Avatar
well considering he has a 9 bolt if he put et streets instead of nitto's 11's should be easily reachable low eleven's possible.
Old Nov 19, 2002 | 10:10 AM
  #18
99 LS1 WS6's Avatar
Sorry i didn't list the other mods
I had the heads ported and polished
comp 216,216,.538,.538,114lsa cam
hooker lt's
SLP y-pipe
corsa cat-back
1.7 roller rockers
4.11's
As for traction i do have slickls that i run when im at the track.
I agree 8 grand is alot to spend at one time but understand thia is where ever red cent that i make goes. I don't spend money on anything other than my car (hey maybe thats why i can't keep a g/f)
Old Nov 19, 2002 | 10:25 AM
  #19
My84Z's Avatar
How many pounds of boost are you running and why when you were in there didn't you do any mods to lower your compression or save your engine?
Old Nov 19, 2002 | 10:31 AM
  #20
99 LS1 WS6's Avatar
I am running 9 pounds. I hate to sound dumb but im not exactly sure what the compression was lowered to but i did have the rods and pistons switched as well. Ill find out and let u know
Old Nov 19, 2002 | 11:20 AM
  #21
My84Z's Avatar
well if you had the whole engine done with forged internals and lower comprression pistons run much more boost man if you did it right with the s trim you should be able to get some good boost out of that thing!
Old Nov 19, 2002 | 04:33 PM
  #22
99 LS1 WS6's Avatar
The compression was lowered to 9.1:1 not sure how much that is over stock. Pistons and rods are forged (not any name brand). I was told that 9 pounds is good for now seeing as my car is a daily driver
Old Nov 20, 2002 | 07:26 AM
  #23
My84Z's Avatar
nice i bet you could get away with up to 16 lbs of boost! well doesn't matter if you get the z06 anyways.
Old Nov 20, 2002 | 09:25 AM
  #24
PhantomTA's Avatar
Moderator
Im trying to figure out how you have Long tubes with an SLP Y-pipe.
If you have forged pieces its goin to be a namebrand. you cant walk in to an autozone and order forged pieces for a ls1.
Im completely confused now that i look at your mods.
Did you say you have an Auburn differential in a 9" 12 bolt? You sure about that?
What brand of rockers do you have?
Old Nov 20, 2002 | 09:35 AM
  #25
u8dusst's Avatar
Somefing smells like **** Timmy!!!
430 RWHP with tuning on a blown LS1 with H/C running 9 psi? Wow, pretty sh!tty numbers. Whats your A/F ratio?
Old Nov 20, 2002 | 12:14 PM
  #26
WhiteDeathLS1's Avatar
Yea bud, your numbers are relatively low when you consider the amount of boost (9lbs) with a 9.1:1 CR. I also agree that you cannot run a SLP Y-pipe with LT's...
Old Nov 21, 2002 | 11:20 AM
  #27
PhantomTA's Avatar
Moderator
ttt
Old Nov 21, 2002 | 11:26 AM
  #28
Ai's Avatar
Ai
How can you run 9psi and only make 430rw...
Any good pair of heads on a stock shortblock with a small cam (224/230) will make over 425rwhp... for about $2300...
more cam.. 440-460rwhp... still cheap...
Old Nov 21, 2002 | 01:24 PM
  #29
Silver NJ_Z28's Avatar
I think you just got busted man.
Old Nov 21, 2002 | 03:42 PM
  #30
2001 LS1 SS's Avatar
What the heck is up with this kid 99 LS1 WS6. I think his car is a bunch of. Kid probably drives a '73 pinto gt. He's on a bunch of posts and has no idea what hes talking about on anyone of them. I wonder how old this kid is
