Super Sucker Ram Air
Old Jun 16, 2004 | 08:23 AM
falchulk's Avatar
Can someone that has this tell me what the install proccess is? Any cutting involved? I cant seem to find instructions anywhere.
Old Jun 16, 2004 | 09:48 AM
shortdog273's Avatar
You have to cut the bottom of your airbox out and the plastic shroud beneath it.
Old Jun 16, 2004 | 01:19 PM
ratio411's Avatar
Don't just jump into a cold air kit if you haven't done some research.
If you have ignore my post.
In areas where you get average/heavy rainfall, there is a risk of hydrolocking your engine... complete destruction for your engine in most cases.
It is not common, but more than a couple guys have done it.
If you live in like So. Kalifornia or Arizona, I wouldn't worry.
Just food for thought.
Dave
Old Jun 16, 2004 | 01:29 PM
teke184's Avatar
i live in south florida...and have had no problem with the heavy rains we get.
you just have to drive a bit more cautiously...and drive slower through puddles.
you have to cut the bottom of the air box out, which i was able to do with a hack saw blade that was broke in half...so obviously it isn't hard.
i don't recall cutting any schroud....you have to remove some of the schrouding...but they all just clip into place with plastic "push pins"
i have some good pics on page 2 of my webpage in the sig
Old Jun 16, 2004 | 02:08 PM
99blackSS's Avatar
http://installuniversity.com/
Under install documents they have directions on how to do the FRA mod, SSRA would have you do an extra step or two. Yes, there is cutting involved and I recommend using a dremel tool.
Old Jun 16, 2004 | 02:22 PM
falchulk's Avatar
Thanks guys. I am aware of the hydrolocking potential. Fortunately my z28 is a garage queen. She does not leave home in the wet stuff.
Old Jun 16, 2004 | 10:26 PM
Flat_Tire_'s Avatar
I couldn't get the 3 circular snapping pins out of the bottom shroud/bumper to save my life .. so I ended up cutting along the bottom edge with a dremel .. That and the bottom of the airbox are the most difficult parts of the install and they're all too easy .. SSRA is a good mod IMO .. if you want to guarantee you don't hydrolock during a rainy day, buy a piece of foam to jam up there during bad weather .. problem solved.
Old Jun 19, 2004 | 04:07 PM
hurricaine418's Avatar
ditto on the dremel. i used an air hacksaw and drill and it looks like crap.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
LT14LIFE
Feb 9, 2015 09:35 PM
rjc1629
Jan 27, 2015 10:46 AM
TitoPR221
Parts Wanted
Jan 10, 2015 09:21 AM
