Sub Frame Connectors
Old Jun 18, 2003 | 08:32 PM
CHRISCAMARO's Avatar
i am thinking of getting some subframe connectors -will this help me with the loss of traction on the line (other than stickier tires)? Or do i need a panhard bar or something else adn what should i pay for this? Also, do you guys get it welded or bolt it on?
thanks
Old Jun 18, 2003 | 08:51 PM
Black6SpdTA's Avatar
You're gonna want to weld them in definitely. Boxed sfc's have a little bit lower ground clearance but stiffen up the car more. even with regular SFC's you will notice a heck of a difference. Check out this thread:
http://web.camaross.com/forums/showt...=weld+much+sfc
Old Jun 18, 2003 | 10:51 PM
norcalstreet's Avatar
Control arms and relocation brackets will plant your tires better than subframe connectors. Ideally you'll want the whole setup- subframe connectors, control arms, relocation brackets and panhard bar.
I would say get the subframe connectors first to reduce flex but since your goal is to improve your holeshot control arms and relocation brackets are more ideal.
Old Jun 18, 2003 | 11:15 PM
Cole's Avatar
SFCs are a great mod, but don't help much in the traction department.
LCAs seem to be the best mod for traction from what I have read.
Jeff1904
Jun 5, 2016 05:00 PM
football4life
Oct 4, 2015 07:48 AM
Double aught
Oct 2, 2015 11:29 PM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
