Sub Frame Connectors
i am thinking of getting some subframe connectors -will this help me with the loss of traction on the line (other than stickier tires)? Or do i need a panhard bar or something else adn what should i pay for this? Also, do you guys get it welded or bolt it on?
thanks
thanks
You're gonna want to weld them in definitely. Boxed sfc's have a little bit lower ground clearance but stiffen up the car more. even with regular SFC's you will notice a heck of a difference. Check out this thread:
http://web.camaross.com/forums/showt...=weld+much+sfc
Control arms and relocation brackets will plant your tires better than subframe connectors. Ideally you'll want the whole setup- subframe connectors, control arms, relocation brackets and panhard bar.
I would say get the subframe connectors first to reduce flex but since your goal is to improve your holeshot control arms and relocation brackets are more ideal.
autoxr166
Sep 25, 2015 04:21 PM
