Stubborn Oil Filter
I tried changing my oil today and I couldnt get the damn Oil Filter off! Is there a cetian filter remover that is more specific to removing these filters? Or do I just happen to have a freak hard to remove filter? BTW this is the first oil change so its the filter that came with the car.
2002 Camaro Z28 A4, 3.23
Monterey Maroon Metallic
Stock for now until I decide what to install.
I know what I am about to say sounds a little radical, however it will work.
If your filter is that hard to get off, drill a small hole in the bottom lower side of the filter, and insert a srewdriver into it, and start tapping the head of the screwdriver with a hammer, this should loosen it, you could also try a large plumming wrench (not monkey), and clamp down on the lower end of the filter until it crushes, and then turn it off.
I have used both methods on my Astro van when the filter would not come off, both times with success.
SteveC
SteveC
Jul 4, 2005 05:00 PM
