Stroker
you could put in a 3.5" stroke into an LT1 and reuse everything with a Felpro gasket... but that's only because of the stock assembly being 0.025" in the hole.
That would turn a 350 ci LT1 into a 352 ci stroker!
Seriously though... for any decent stroke increase, you need to either decrease the rod length, or the compression height of the piston (distance from the center of the wrist pin to the face of the piston).
If you don't make the rod/piston combo shorter, the longer strike will throw them into your heads... good bye engine.
RUENUF
Mar 13, 2016 03:37 PM
