stock Z28 tires
Old Sep 22, 2003 | 01:06 AM
WazzuZ28's Avatar
stock Z28 tires
Has anyone else experienced problems with the front tires cupping? I have 7,000 miles on the Z and I know it is time to rotate the tires, but the fronts are cupped extremely bad. I don't corner the car that hard, just get on it in the straights. They are the stock 245/50 series Goodyears GS-C's. If anyone has experienced this problem have you had any luck getting warranty replacements from Goodyear???
Old Sep 22, 2003 | 01:10 AM
99blackSS's Avatar
By cupping do you mean the insides wear less then the middle?
If the middle wears more they are over inflated. If the sides wear more its under inflated. If only one side of the tire(s) wears more then your alignment probably needs to be fixed.
Old Sep 22, 2003 | 01:54 AM
autoguy's Avatar
hey.. i have the same problem... except all 4 of mine are doing that... i dono why.. i rotated the tires almost 2 K miles ago and it's still doing the same thing... not sure as to why... i have the 245 50 16 good year eagle RS A.... the car drives straight... and fine.. but not sure as to why it does this... any ideas guys and gals?
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rockync7
Jan 1, 2015 05:10 AM
siguy
Nov 27, 2014 10:07 AM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
