stock rear gear ratio, '01 Z28
Old Dec 15, 2002 | 09:20 PM
  #16
DS01Z28's Avatar
tire size & rear gears...
Now you've got ME confused! I have 245/50ZR- 16's on my 2001 Z28. If the GU2 means I have a 2.73 rear gear ratio, then how did I do 142mph in it? Ah heck... now I'm wondering if I need to reprogram my PowerProgrammer from a 2.73 to a 3.23 rear?
Ugh!!!
DS01Z28
Old Dec 15, 2002 | 10:40 PM
  #17
Pentatonic's Avatar
Re: tire size & rear gears...
Ugh!!!
DS01Z28
The 2.73 gears will give the car a higher top speed than 3.23 gears.
If the sticker on the door says GU2, then you have 2.73 gears.
Old Dec 15, 2002 | 11:40 PM
  #18
Capn Pete's Avatar
Arrow Re: Re: tire size & rear gears...
Will A4's with 3.23's not hit ~160mph?? (or anything over 150mph?? ). I know my car (with 2.73's) was still in 3rd gear above 150mph, but will cars with 3.23's not hit that speed in overdrive??
And DS01Z28..............there's nothing wrong with your car! Since you've got Z-rated tires (from the factory) you don't have the low speed limiter, therefore you can do over 115mph, and upto ~163mph if you're brave enough!! Pretty much the only time 2.73's are good is out on the highway for top-speed runs.
siguy
Nov 27, 2014 10:07 AM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
