Stock LS1 M6 1/4 mi times
Re: Stock LS1 M6 1/4 mi times
Originally Posted by buzz12586
I talked to him and he said he was shifting at like 5500-5800. So I told him to shift at 6 grand and he is gonna try it next time.
Originally Posted by robb4964
Corvettes can shift at 62 I think ....f-bods are limited to 5800k . So if he is stock he wont be able to shift past that
. The factory rev limiter is set at ~6200 RPM or so for F-bodies as well
('til I raised it up with the Hypertech to about ~6400 RPM). Even my buddy with an LT1 M6 shifts at about ~6000 RPM at the track
Originally Posted by QCKZ28
the best my 2 friends that have M6 ls1 transams are as follow
2001 WS6 went 14.2 at 101 2.2 sixty foot
2002 WS6 went 14.2 at 101 2.2 sixty foot
bone stock except muffler on both cars
my A4 stock 02 Z28 went 13.8 at 99.9 with a 2.02 sixty foot on et streets (26x11.5x16) only mods are flowmaster muffler and 3.73 gears...
elevation 1744 sucky weather (hot/humid) the density altitude is around 3000 to 3500...
Originally Posted by Capn Pete
Not true
. I know 'cause I've hit it before!
I shift at 6,000. I have never seen my car hit 6,200. My bone stock 99 M6 went 13.54 at 105 with a 2.00 60' time on street tires. I am good at launching the car, but I just can't seem to break into the 1.9's with the street tires. I just picked up a set of well broken in Nitto drag radials, so we'll see. I should be able to go 13.30-13.20's with those. Weather permitting I am going next Wednesday. I will let you know how it goes. Could be the night the clutch finally breathes it's last breath (its tired).
I want to see time slips! I go the track a few times a year and I'm not the only LS1 on the track. I've never seen a stock LS1 hit into the 12's! I know it's a lot to do with the driver, but I know guys that have been racing for years driving Fbods and still pulling mid 13's all day long. Does anybody have slip to back up these times?
How fast are you shifting ? With that kind of 60 Id think your car would be already running 13.30's or so . Stock ? With drag radials you may Hit 13.0's . Good luck .
I dont think stock limiter hits at 6200 because it seems like if i dont shift right at 6000 the rev limiter kicks in.....so to me it seems like about 5900-6000. There is for sure no way i could hit 6200.
If you are runnin these times with these cars theres something seriously wrong....i have a 2000 ws6 m6 and run 12.9 with a tire, and the cars all stock except for cutout
I think I am shifting pretty darn fast. Maybe I suck, but I think I am really good at banging the gears on the T-56. After hearing all the other times on here, I am a little disappointed with my time as well. I am pulling a better 60' than most, but I am slower than most. I guess when I go Wednesday I will play around with shiftpoints, and make sure I am shifting fast. I would love to hit 13.0's, but I don't think it is a reality with the tired clutch. I only made 3 passes with my old BFG drag radials, but I was not impressed. Hopefully these Nitto's will be better, at least they feel better on the street! We'll see. Thanks for the good luck wishes, I am afraid of breaking something if I hook up real good,
Originally Posted by falchulk
The tach lags behind actual rpm. Thats why shift lights are so popular.
). Fine, with an automatic the stock shift points are set at about ~5800 RPM, but if I shift the car manually (before adjusting with the Hypertech) then I could hold the shifts out beyond 6000 RPM
.And for any dis-believers that a stock LS1 can't do a 12.xxx, maybe I haven't actually seen it either, but I don't doubt it. Look at my 1/4 mile times (with 2.73's or now 4.10's).....the times w/2.73's were on crappy tires, vs. with the 4.10's now, I've got tires that hook really well. SO, the power is getting put to the ground. If my car were an M6, which uses less engine power, then I'd probably be able to get my car to hit a 12.xxx AS LONG AS I COULD SHIFT!
