Starting problem when I refuel
Old Apr 27, 2007 | 07:02 PM
airforceSS927's Avatar
Angry Starting problem when I refuel
About half of the time I refuel, my car doesn't seem to get any fuel to the engine at all until it cranks for about 5-7 seconds and then it doesn't idle right for a couple seconds. After all that it runs like a champ until the next time that it does it after refueling. It doesn't do it all the time, though, and when it does it's only after refueling. Does anyone know what this is and why it does it only on occasion at a certain time?
Old Apr 27, 2007 | 09:24 PM
Z28luvr's Avatar
Are you running the tank really low? Maybe a pump issue. Carry a gauge with you and the next time you fill up, check the psi.....should be right around 58. You might want to check/replace the filter as well.
Old Apr 28, 2007 | 12:36 PM
I usually have at least a quarter tank when I refuel. What guage are you talking about and how do I use it?
Old Apr 28, 2007 | 04:30 PM
smithtim's Avatar
think Z28luvr is talking about a fuel pressure gauge, here's a quick link to one at sears but it's kind of pricy probably can get one for less than half of price they ask
http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
Also, like said above, changing the fuel filter is a quick & inexpensive which is routine maintaince anyway so I'd start with that
Old Apr 29, 2007 | 02:52 PM
Z28luvr's Avatar
I am talking about a fuel pressure gauge. You can get one for about $35 at Advance or Autozone. Screws into the schraeder valve at the end(front)of the fuel rail. Just make sure to bleed off the pressure before you unscrew it!
eazyZ
Mar 1, 2015 07:12 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
