Starter? Ignition Switch? Clutch/Starter Switch?
What do you think is going out? the car just clicks one time and wont turn over. I bench tested the starter and it read fine but showed a low voltage light.
If the starter had a low voltage problem..wouldnt it still at least atempt to turn over?
Could it be that the ignition switch went bad? How bout the clutch/starter switch?
BTW..wont start in any gear/neutral/reverse.
Oncomingstorm22
Jan 22, 2015 07:15 PM
