Spark Plugs... worth the hype?
Old Apr 26, 2003 | 09:21 PM
gearslammer's Avatar
Since almost everything else discussed here is performance oriented, what about the plugs? Best, worst, stock o.k.?
Old Apr 26, 2003 | 10:37 PM
NC Dude's Avatar
Depends on what your doing with the car. Normal street duty? Drag racing? Auto x-ing? Motor.... Stock, mild bolt-ons, heads/ cam?
Your intended use will dictate which plug you should run.
Old Apr 28, 2003 | 11:31 AM
psychocabbage's Avatar
I dont see why stock plugs (arent they plat tipped?) wouldnt do any better than any other plug for your daily driver.. Sure if you go to boost and spray you will need different temp plugs and whatnot.. but for just a stock car? I dont see plugs giving you anything more than others.. When I eventually do change out mine (many many moons from now) I will use Bosch Plats.. just cause I like them... Not those double or quads either..just standard single electrode bosch plats.
Old Apr 28, 2003 | 01:59 PM
kinyu's Avatar
For what its worth, my WS6 friend got some of those multiple electrode plugs and hated them. The multis didnt get hot enough to ignite as well as his stock plugs. IMO, those plugs seem better suited for 6 and 4 bangers.
Devinfoote87
Feb 12, 2016 03:21 PM
colts0455
Sep 2, 2015 12:41 PM
mark0006
Aug 29, 2015 09:45 AM
truthmatters
3rd Gen / L98 Engine Tech
Aug 19, 2015 04:09 PM
whitehooptie
Aug 17, 2015 08:35 AM
