Spark Plug Wire Swap
Old May 30, 2003 | 06:34 PM
Ferocity02's Avatar
When replacing the spark plug wires with Taylor "409" wires, do you have to re-use the the stock metal tube and spring that is around the wire down by the the headers? I noticed that the ends of the new wires do not fit into these cylinders. Do I need to get something else to protect them from the heat? Thanks
Old May 30, 2003 | 06:57 PM
amood's Avatar
I bought Taylor Thundervolts and had the same question! They sent the wires with appropriate heat shields....but call and make sure they aren't sold seperately. I say this because nothing is a suprise anymore....except constant service with the customer in mind!!!!
Old May 30, 2003 | 09:27 PM
Ferocity02's Avatar
I talked to some other people with Thundervolts also and they say you do not need any heat shields.
Anyways, how do I access every wire on the passenger side of the motor?
Old May 30, 2003 | 09:48 PM
#7's Avatar
http://www.installuniversity.com/ Look in "Install Documents" under "Engine". You can move the coil pacs and AIR tubes to get more room.
Your only doing wires? Why go thru the hassle and not do the plugs at the same time?
Old May 30, 2003 | 10:04 PM
Ferocity02's Avatar
Because I hear new plugs aren't worth crap
Old May 31, 2003 | 10:57 AM
z28chrizz's Avatar
I just put the bosch platinum +4's in my car after 24k on the oem ones. I was suprised at the increased throttle response and improved idle. The OEM plugs were burnt and the gap was off bigtime on all the plugs. I would definitely reccomend doing the plugs if you are going to fight with the stock wires anyhow.
Old Jun 1, 2003 | 02:48 PM
KungFu's Avatar
You hear these things from Ford ppl? hehehe j/k
I'd change the plugs if they haven't been changed in awhile.
Old Jun 3, 2003 | 12:24 AM
fbird95's Avatar
I had serious problems with 2 sets of the bosche platinum plugs and wires , so i was surprised to see a success story. Good Luck with them.
As for any wires i wouldnt use the factory looms, they hold the wire far to close to heat sources, its almost as if GM wants them to burn up over time. I use cable ties instead.
94Z28LS1toLT1
Feb 28, 2015 08:33 PM
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
Jazsun
Dec 29, 2014 12:14 PM
DubbyZ28Camaro
Aug 4, 2002 12:53 PM
