So what maintenance should i do on my car before i head back to school?
Old Dec 29, 2006 | 01:04 AM
Skyhawk's Avatar
Question So what maintenance should i do on my car before i head back to school?
Well, what should i do before i head back down to Jax here in 2 weeks while i still have the luxury of a garage and private driveway? The car has 62K miles on it now, and i bought it when it had around 50K and all ive done on it so far are the oil changes and transmission fluid change. What else should i do? Ive got new tires on order for it, and theyre going on it next week. Should i change the spark plugs and wires? Is there anything else i can do to it at 62K? Also, what other maintenance do i have come up? (ex: 70K, 80K, 85K miles, ect...)
Old Dec 29, 2006 | 01:09 AM
93Phoenix's Avatar
I'd go pick up your girlfriend before she sticks a banana in your exhaust.
Old Dec 29, 2006 | 01:16 AM
Skyhawk's Avatar
Old Dec 29, 2006 | 07:40 AM
LUDA0840's Avatar
fuel filter, pcv valve oh and I just a brain fart and I cant think of what else...
Old Dec 29, 2006 | 11:17 AM
2000GTP's Avatar
I would go ahead and do the plugs and wires as well. Even though they are platinum plugs with a supposed 100K mile life, they don't live as long as advertised.
Old Dec 29, 2006 | 11:42 AM
GreenDemon's Avatar
Coolant and brake fluid if they've never been done.
Old Dec 30, 2006 | 08:11 PM
Need4Camaro's Avatar
I would say do a full brake job, tuneup, and replace battery...
All of these were EXTREMELY necessary and done at around 70K for my car and the rotors were warped at about 65K
Old Dec 30, 2006 | 09:32 PM
Skyhawk's Avatar
ok so what i have so far is...
oil change
spark plugs/wires
PCV valve change
Fuel filter
Air filter
flush/change coolant
brakes if needed...
Also, what are the recommended mileage intervals for these things?
Old Dec 30, 2006 | 10:50 PM
oil change
spark plugs/wires
PCV valve change
Fuel filter
Air filter
brakes if needed...
Oil Change - Every 3K (duh)
Spark Plugs / Wires - GM says 100,000 miles and I'll be the many to conclude that GM is F.O.S... My plugs were fouled to HELL at just 70K and were in desperate need of replacement. #8 Plug was pitch black and covered in oil. All the platinum was gone on each plug.... Replace with NGK TR55 plugs, Plats arnt necessary...
PCV Valve - 10 - 15K???
Fuel Filter - 15 - 20K???
Air Filter - 15K??? (I just clean mine when it gets dirty...)
Coolant - GM says 150K, once again I'd have it done WAAAAAY before 150K... 100K tops, also Dex Cool has a tendacy of becoming acid enough to eat away the plastic resivior under the battery.
Brakes - Whenever they wear down, they can vary ALOT depending between cars and how you drive.... Mine needed a full brakejob at 70K and my front rotors were warped to hell...
Old Dec 31, 2006 | 01:54 AM
mmmchickenboy's Avatar
if you use high quality synthetic engine oil and oil filter, you can push it out to 6k miles.
Old Dec 31, 2006 | 12:23 PM
I just use the standard Mobil 1 synthetic (not the 15K brand) and AC Delco or Pure One Filter... Is that good enough for 6K? Tell me because I'm all about saving money!
Old Dec 31, 2006 | 01:16 PM
to be safe, i would replace just the filter at 3k.
Old Jan 4, 2007 | 01:27 PM
TheV6Bird's Avatar
Check your serpentine belt to see if there are any cracks, although a squealing noise will generally let you know your belt is worn.
Are there any chassis grease fittings on F-bodies that should be checked?
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
nophix
Nov 30, 2014 10:26 PM
USAirman93
Nov 24, 2014 03:37 PM
Brian-94TA
Jul 31, 2002 02:52 PM
