Smething to check on your cars !
Old Aug 4, 2003 | 09:58 AM
NEWBIE T/A's Avatar
Exclamation Smething to check on your cars !
When I went thru my exhaust rattle experience, one of the things I checked was the spare tire & jack.
When I pulled out the tire, I looked down and noticed a small hole directly under where the tire sits.
This hole leads straight to the outside (bottom) of the car, and was open !!
I plugged it with silicone and duct tape.
So, this means all the time I have owned the car (2 years , 26K) I have had the possibility of carbon monoxide (exhaust) entering the passenger compartment as well as water, noise, etc.
Niiccee ...
I went to the dealer, but we were unable to pull up a picture of this area to check for a plug P/N.
Typical - my SS buddy here at work did not drive his car today, so I can't look at his.
Anyway, let this serve as a head's up.
Britt
Old Aug 4, 2003 | 10:11 AM
Aklaim's Avatar
That is a drain hole. In case your hatch leaks or your antenna leaks and water enters it drains out rather than sitting . I would unplug that. You won't get carbon monoxide poisoning from leaving it open.
Old Aug 4, 2003 | 10:36 AM
99blackSS's Avatar
All Camaros have that hole. Don't worry about it, its a drain like the person above said. Its especially helpful for power antennas which require a drain.
ChrisFrez
Dec 21, 2014 09:47 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
