SLP harmonic balancer
Old Jan 28, 2008 | 11:03 PM
kyle67camaro's Avatar
I just got started putting my harmonic balancer on my 98 ls1. I got the old one off and I saw that the old one doesn't have a key way or timing numbers on it, but my new slp one has both a key way and timing numbers. So I am just wondering if I need to put the new one on any certain way or not. If so how do I figure it out. Thanks so much Kyle
Old Jan 29, 2008 | 06:22 AM
ALZ28's Avatar
Just ignore keyway and timing #'s these are mainly for high boost engines.
Follow instructons ie use old bolt to get as far up as possible then turn new bolt 140*IF YOU CAN mark the pulley at 45*s so you know how far. I got mine to about 120* with a 6ft pole on it.
If A4 you need to jam a large screwdiver in the flywheel on the drivers side behind oil filter and plastic cover. Hope this helps
G-BODYT56
Jan 14, 2022 11:14 PM
Jeff1904
Jun 5, 2016 05:00 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
Daluchman1974
Sep 11, 2015 06:12 AM
