SLP Differential
Old Oct 16, 2002 | 07:35 PM
nexus77241's Avatar
SLP Differential
I am really p'od because I royally spun out today in the bad weather today (and nearly crashed ), so I am going to get the differential. When I get the differential, for my 99 Firebird, what other parts do I need and about how much does it cost to get installed? thanks.
btw I am still very pissed about this!
Old Oct 16, 2002 | 07:47 PM
chuck's Avatar
Do you mean you are going to replace a single-track differential with a posi, or replace the entire rear axle assembly with the SLP 12 bolt?
FWIW, a posi will make the car worse in bad weather. A spin is almost never the cars fault, usually it is a driver mistake or worn tires.
Old Oct 16, 2002 | 08:44 PM
Ken S's Avatar
If i understand correctly...
without a posi you'll gernally just spin the inside tire while apply little to no tq to the outside tire in a turn.. The inside tire is generally less loaded and easier to spin.
with a good posi, it'll transfer the tq to the outside tire when you start overcoming the inside tire.. this will help rotate your car out of a turn...
is this right?
Old Oct 16, 2002 | 09:48 PM
nexus77241's Avatar
no. im not gonna replace the entire axle. my main objective is to get slp part number 64501T the stock torsen t-2 differential from the y87 performance package
Old Oct 16, 2002 | 10:59 PM
chuck's Avatar
All you will need is the posi, 2 quarts of fluid, gasket (or permatex) and someone that is good with gears to install it (all the really have to check is backlash).
G-BODYT56
Jan 14, 2022 11:14 PM
n2oblkz
Oct 12, 2015 01:53 AM
sahlomonic
Parts Wanted
Sep 22, 2015 03:13 PM
tommalcolm
Sep 11, 2015 03:39 PM
rideordie
Sep 7, 2015 08:22 AM
